Everything Basher BSR
yoodoo
Would this be the right pinion gear for the standard Basher motor?
http://www.hobbyking.com/hobbyking/store/__45529__17T_5mm_M1_Hardened_Steel_Pinion_Gear_1pc_.html
Right fitting yh - Mod 1 5mm shaft.  17t will gear it up a little for some more speed.
On an unrelated note mini me announced out of the blue how much he doesn't like rally cars and want's an MT like mine :/  Did the same thing last yr but wanted a buggy not the MT!!!!!
Yaaaay,thank god for indecisive kids:D:D! You got yourself a BSR mate!;)
Well took the kids,dog and missus out today to walk the dog and I slipped my BSR into the car too...along with my Mobius.Took a few of the kids and dog then gave it to my wife to get some action footage of the car.Needless to say she ****ed around with the buttons after me telling her not to and spent 10 minutes recording bugger all:ack: And missed me wiping out the rear hub and pin(totalled)
Still,the dog looked good on the vid:D
J
Not sure if this is right area,
But my Basher Sabertooth needs it's diff oils changed. ( I'm new to all this but I know the stock, factory oils/water/whatever crap it is will be no good. ) Just wondering if anyone has a rough guide on easiest way to strip the car down and what to clean the diffs with, hot soapy water and a toothbrush i'd say? Then dry thoroughly?
Thanks!
Thanks!
Get hold of the manual first, some good tools and a clean spacious work area.  I've not wrenched on that truggy but generally most are very similar.  Remove the shell and wheels first.  Rear end usually easiest - unscrew the 4 screws holding the rear diff to the chassis and lift it away - the centre rear dog bone will fall out (if it's got a cvd it'll come away with the rear end.  You need to access the diff - look at the manual - unless it has quick access diffs you'll likely have to remove the diff housing from the arm hangers.  I usually disconnect the shocks from the top of the tower to make life easier - rear dogbones will fall out.
Once you've access to the diff housings then unscrew to access the diff - note which way round it fits in the housing - not all can be fitted only one way - then time to unscrew the diff.  The manual will help here, but note how everything comes apart carefully - if it's shimmed at the factory you don't want to rebuild it and stick all the shims to one side for example.  Once disassembled you need a solvent to remove the grease / oil that's in there.  Washing up liquid and water will work but you won't get all of it off after, and thoroughly drying takes time.  Most use a solvent that evaporates quickly - ipa (isopropyl alcohol) is good, cheap in bulk (ebay) alternatively you can use 1:! car brake cleaner (££ in spray form) - I use unleaded petrol as taught my the old man when stripping and cleaning old Ford carbs, cyclinder heads etc.  Whatever you use take necessary precautions.
Reassemble in reverse order, check everything mesh's up nicely and that's about it.  There's likely lots of video's on the tube of you to help.  Front end is a little more involved as it will be connected to the steering set up - most times you can get away disconnecting the steering arms from the knuckles, unscrewing the top plate from the diff and sliding it out - the manual will help.
Looks great Matt,nice short vid too! Do you have links for the items you have put on it?
J
For some reason I can't post links or vids from my phone so when I get home I'll get the laptop out and sort out the links for you.
You sir. Are amazing. I'm going to crack on with it tonight... Will take me a few days i bet but thank you ever so much.
Sent from my SM-G901F using Tapatalk
Your welcome - some find it tedious but I actually find it quite relaxing.  Old toothbrushes (or the Mrs') are highly recommended for the cleaning part.
"Old toothbrushes (or the Mrs') are highly recommended".....:D:D:D....Just hope she doesn't read this....sweet!:thumbsup:
Double post evilness!
On much deliberation, and discussions with mini me, his BSR Rally will be going up for sale, anyone in here wants first dibs before I list it feel free to pm me.  Happy to let it go as a roller or artr (Tx/Rx has been got rid of - it was carp).  It's still in it's box as new obv, unrun.
PM'ed Craig.
J
J
Sorry I didn't put up the links sooner but I have been flat out busy.
I fitted these front and rear.
  https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=64270
I had to get these and use the front tower and drill holes for the body mount.
http://www.ebay.co.uk/itm/ANSMANN-DEUCE-N-FRONT-REAR-SHOCK-TOWER-SPARE-PARTS-NEW-/310393660608?hash=item4844e764c0:m:mJsTN6UHkttqLrn4mDBFH8A
Instead of getting 2 sets of the fronts you could get a set of these and use the rear tower as there is plenty of room under the body.
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=64271
What were the shocks like? What set up are you using now? I have just received through the post my new tyres and wheel...uber soft cmpound for the winter...Vid when fitted but have to wait on my rear hubs as they took a pounding with a kerb and the kerb came out top!:ack:
J
I've set everything to the max so the shocks have maximum travel it drives lovely, i highly recommend doing it when you order the shock get a couple of pack of the uprated spring kits.
Did you say that the rear hub was snapped on yours? I've just fitted a set of front CVD's to the rear of mine they fit perfectly, I can't tell you how it drive yet though as one of the grub screws was rounded off in the hub and I managed to break the 17mm hex off getting it out.
Mini me's has gone on fleabay - if anyone here's interested feel free to shoot me a pm and i'll list here if so required.
:/  Kids Huh!
sorry mate I forgot to get back to you my mate had already ordered the trooper, after looking at it I ordered myself one as well looks good for a bash.
It's cool bud.  It'll go, and if not the combo will go in a buggy and I'll use it as a speed run chassis if and when work picks up.
