gumbo Posted November 2, 2014 Share Posted November 2, 2014 Hi,could someone give me some advice on a engine upgrade,i have a xtm xt2 with a .24 in it i think it could do with pepping up a bit.Any ideas with what also should it be a straight swap what do i need to look out for.thanks. Quote Link to comment Share on other sites More sharing options...
speedods Posted November 2, 2014 Share Posted November 2, 2014 i hear these are good bang for buck: http://www.modelsport.co.uk/fastrax-enduro-twenty-one-3-port-nitro-engine-ps/rc-car-products/380746 Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted November 2, 2014 Share Posted November 2, 2014 Stock XTM motor is a .25 ... It's basically a rebadged Force engine. Not a bad unit for a buggy. Engine choice really depends on your budget. If you are looking for a cheap upgrade, then a Force .28 will give you a bit of a boost. If you have a bit more to spend...look at an LRP .28 Quote Link to comment Share on other sites More sharing options...
gumbo Posted November 3, 2014 Author Share Posted November 3, 2014 Would all the above be a straight swap over?or will other bits need to be changed. Quote Link to comment Share on other sites More sharing options...
gavin28 Posted November 3, 2014 Share Posted November 3, 2014 Should be a straight swap, you will have to remove the flywheel and clutch from your old engine and install on the new one, but that's about it. Quote Link to comment Share on other sites More sharing options...
jizwizard Posted November 3, 2014 Share Posted November 3, 2014 give me a text mate on your budget Quote Link to comment Share on other sites More sharing options...
