Show us your Buggy!
The photos a bit blurry sorry.
Firstly you can see its hollow so dirt would get in there and secondly you will see there is a pin holding the hex on which is secured inside that hollow with a 4mm grubber screw.
So yes it saves the wheel bolt from flying off somewhere but also the gubberscrew.
had another good run today with the hyper :P
Didnt visit the hill tho :(
But i tried jumping :P
weren't bad... ALOT of rough take off and alot of rough landings....
I lost a Steering screw :( And i'd been driving 2 mins - and didnt wanna walk back to get sumet :P
So my solution?
Stole a body clip off the body and it really does work :D
I lost my heatsink protection thing as well :(
But pink tubing will have todo for now :lol:
Ziggy
Not bad ziggers. I've been working on the EB4 S3 today. I've got the front fully rebuilt bar putting the shocks back on, and a new top plate. I'm probably going to sell it when i've fixed it though as i like stadium trucks more (might be a firestorm hehe)
Euan congratulations for the most beautifull HYPER 7!!!! :36_1_32v[1]:
Please send infos where i can buy black rims - black rear spoiler - black lexan
regards...
The black spoiler euan is using aint stock - he's got a dferent brand HIGH downforce wing - sumet like this
Rims - Are like these
Shells been sprayed from clear :)
Ziggy
That is really nice, I wanna do my buggy out in black (maybe with some white wheels though) got the body and stuff on its way. ;)
U know B+W Makes a good mix and match :)
Since u can get like black side trims and u can dye the radiobox etc
Spray shells black
White rims with black wheels
White shock springs with black socks - makes a great mix and match :D
I will Eventually do it myself....
Ziggy
Spray shells black
Ziggy
you cant die the radio box it has to be sprayed
Hehe
Haz is back!! AND RUNNING!! :o
After the issue in this topic :P
Previously while i waiting i spent 2 whole days cleaning her :) Full strip down :) bearing maintance / grease etc etc
Anyway - Haz During her rebuild
and her rebuilt
Now she's back together - i got cliky fingers....
Trouble is - they all look the same :(
That Hook that holds the exhaust in place - now a green wire coat hanger :P
Hard to see tho :( Suits the overall colour tho :P
had to reseal the Exhaust/manifold
Green and blue make an intresting mix and match :)
And my poorly pullstarter - i broke it - fixed it - just need to retension it :P
And that all from me for now :)
Ziggy
ziggy .... ure attempt at attaching the pipe to the elbow is feeble ... i got my pie in about 3 cm more than u
cos im a brute...... holding a hairdryer :P
theres only one problem with ure hypers ... there all so .... stock !
heres mine
hop-ups
spekki
new wheels
new wing
new shell
hyper .21 8 port pro engine
new hyper polished pipe
dynamite throttle linkages
craddock anti-lock brake disks
full metal brake pads
venom smart temp
stutter stopper
carbon fibre diff plate
carbon fibre servo tray
new generation fuel tank
pbs conversion kit
hitech 645 servo
spektrum throttle servo
white springs
black shock socks (not pictured)
spider diff still to be fitted
exhaust deflector
k-factory unbrakeable antena tube(not pictured)
new black reciever box and battery box
venom 1200mah flatpack
in total about 500+
ziggy check the pipe on the elbow look the cable ties and the pipe are up 2nd notch!!
(excuse the photo quality, i used my camera phone) ok, i havn't got the bits i want for it yet to make it look, but heres what happens when you fit truck wheels on a buggy 'cos you're bored...
it has NO rear grip on grass, it's fantasticly slidey :P on road it actually squeels :D
Edited by halcalanky
i have loads .... but that shell is the stock one painted with halfords rattle cans on top of the shell :P ... look at the window u will see a bit of the old paint
