The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 i am on a new contract... the client was wrong with the prediction of calls per day haha Quote Link to comment Share on other sites More sharing options...
thecorn92 Posted June 14, 2009 Share Posted June 14, 2009 thats baaaaad lol, i have too much to do, trying to get an IT apprenticedhip Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 quick question, when my cars idling, sitting still should there be smoke? Quote Link to comment Share on other sites More sharing options...
thecorn92 Posted June 14, 2009 Share Posted June 14, 2009 a little but not too much Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 the other day when i was idling there was none..... just loads of full spewing out Quote Link to comment Share on other sites More sharing options...
thecorn92 Posted June 14, 2009 Share Posted June 14, 2009 u need to lean it out about an 1/8th off a turn, thats the needle where ur fuel line is attached, turn it clockwise Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 i thought it was fine to run it rich during break in? Quote Link to comment Share on other sites More sharing options...
thecorn92 Posted June 14, 2009 Share Posted June 14, 2009 well yeh but if its dying cos its too rich u need to sort it out to break it in, if its not bogging down i would leave it, but once u have run it in, it needs sorting Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 yeah, thats what i thought, ty Quote Link to comment Share on other sites More sharing options...
KieranBolton Posted June 14, 2009 Share Posted June 14, 2009 Where about on the scottish borders are you mate? kieran Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 Near Galashiels, why? Quote Link to comment Share on other sites More sharing options...
KieranBolton Posted June 14, 2009 Share Posted June 14, 2009 just wondering thats all because i would off came and give you a hand, are you friends with netcon btw, im just sout of newcastle Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 yip, netcon and i been talking, u got msn kieran? Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 i think i got it.. it is idling, and when braking the engine doesnt stall... woo Quote Link to comment Share on other sites More sharing options...
BRUN Posted June 14, 2009 Share Posted June 14, 2009 congrats ! Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 only downside is i had to alter Th. Trim on the Tx.... this likely to do much damage? Quote Link to comment Share on other sites More sharing options...
BRUN Posted June 14, 2009 Share Posted June 14, 2009 nope but if you had to use that maybe you still have too small a gap on your carb using the idle screw Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 14, 2009 Author Share Posted June 14, 2009 the idle screw will make gap smaller but when i pull starter it gets big again.... Quote Link to comment Share on other sites More sharing options...
eb-4:20 Posted June 17, 2009 Share Posted June 17, 2009 man i got the hsp tyranno/behemoth......man they are pain in the hole..... i had the same prob with mine, i adjusted the coller's on the throttle linkage to correct the issue... also the little piece on the carb were the link connects to has to grob screws in it around the side's, took me ages to suss it, but the link piece was moving on the carb, but carb werent opening, screwing in the idle screw will open the gap in the carb, manual recommends a 0.8 - 1.0 mm gap, you also wanna check for air leak's, if it's the .18 vx , rip it out, take the back plate and carb off, get yourself some copper silicone gasket sealent, (better than red as it handles a constent 300* + ) seal up the carb and back plate, allow a few hours to dry and try again, also the stock fuel line on these thing's are just about good for show only! change them to summat decent like the venom fuel line,... might surprise yourself........ many hour's, too many head ache's, and a bottomless pocket and mine run's ok now ....but i wouldnt recommend hsp to any one, unless it was mine you was buying .....' and dont bother with half the alloy crap for it, really not worth it, shock tower's, servo saver, and alloy steering and camber linkage's, these also double up for the steering servo..... and a set of shock's as stock are like summat youd from argos for a tenna ...' you got a tuned pipe or plastic stock one ? a tuned pipe will make a big diff on the idle of these vx's too... i think the newer one's have the team infinity unit's in them... Quote Link to comment Share on other sites More sharing options...
The Trooper Posted June 17, 2009 Author Share Posted June 17, 2009 plastic pipe mate, thanks for tips, but i broke car... i need to repair it http://www.msuk-forum.co.uk/index.php?showtopic=59927 Quote Link to comment Share on other sites More sharing options...
