Hell horn. Posted January 29, 2022 Share Posted January 29, 2022 Not sure where to put this. I'm wondering if anyone on here can design something for me. Simple item. 18mm x64mm tube. To go in a set of wheels to make it beadlock. Thats about it. Thanks guys. Pm me it you want to. Can chat about them a bit more in depth then. Quote Link to comment Share on other sites More sharing options...
BigGinge Posted January 29, 2022 Share Posted January 29, 2022 Do you just need the design file for this or do you need some parts as well? If it’s just the design then I should be able to help (assuming you need/want something heavier than 3D printed plastic for the final parts). 2 Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted January 29, 2022 Author Share Posted January 29, 2022 It's just the design. I can get a mate to print me some. Will pm you dude thanks 2 Quote Link to comment Share on other sites More sharing options...
Stevelyt Posted February 5, 2022 Share Posted February 5, 2022 Did you get what you wanted, if no I may be able to help Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 I got some fantastic help from big ginge. But Need a couple other bits doing if your interested. Body mounts for my chassis im working on. And maybe a few other down the line. Will pm you about it. Thanks dude Quote Link to comment Share on other sites More sharing options...
Redback Posted February 5, 2022 Share Posted February 5, 2022 I do some printing, 3d posts will probably not be very strong, due to the layering etc. Theres also alex and everclear that can print. Your not short on choice 🙂 1 1 Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 Thanks dude. So the post won't be printed. The cross member with the post mount in it is only to hold the body on. Its not for strength. Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 Printing isn't really an issue. I can get that done. It's the design work needed to print I need help with. 2d stuff I'm fine with. 3d stuff is beyond me currently. Quote Link to comment Share on other sites More sharing options...
Redback Posted February 5, 2022 Share Posted February 5, 2022 Yep pretty sure they will design for you too as they make their own parts. I also do design. 😉 👍 1 1 Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 Impressive. I'm after one last important part. The gearbox mount /sump. I have one done in derlin but need it to be 3d printed for cost. Cnc delrin is far to expensive at my stage. Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 This. But extend the 2 center parts by about 10mm each side. And have then slop up to help the car slid over stuff better. Have all the dimensions required. Just Need it programmed. Way way way out of my skill range at the moment. Wheel inserts are done and 1dt set printed. Body mounts are designed just need to test print. Then it's sump to do. And I can get a few sets made up and tested for me. And make adjustments needed then 1 Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 Super bad pic for you lol. But that. Extend center to help it slid better. Quote Link to comment Share on other sites More sharing options...
BigGinge Posted February 5, 2022 Share Posted February 5, 2022 Have tried mounting up the wheel spacers yet. Did they fit ok? Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 @BigGingenot yet. Still at a mates house. We all have covid now. So can't pick them up yet. With sucks. He is also printing me a v8 scale engine for my capra. With is being a pig at the moment to work. But fingers crossed for some point this week. They do look fantastic. So thanks for doing them for me dude. Really appreciate it 1 Quote Link to comment Share on other sites More sharing options...
stimpy Posted February 5, 2022 Share Posted February 5, 2022 Ah!!! Your messages all make sense now!! 🤣 1 Quote Link to comment Share on other sites More sharing options...
Hell horn. Posted February 5, 2022 Author Share Posted February 5, 2022 I bet they don't. It doesn't normally to me so. 1 Quote Link to comment Share on other sites More sharing options...
ThePoacher Posted February 6, 2022 Share Posted February 6, 2022 Sorry to hijack.. but can anyone print a fan cover on a hobbywing esc? The original one has broken. Quote Link to comment Share on other sites More sharing options...
Redback Posted February 6, 2022 Share Posted February 6, 2022 5 minutes ago, ThePoacher said: Sorry to hijack.. but can anyone print a fan cover on a hobbywing esc? The original one has broken. Did see your post asking and considered 3d printing being the solution however. The heat might be a bit much unless you can get it printed in ABS PLA isnt suitable as its sensative to heat over 40c and possibly PETG isnt suitable as escs can get over 70c easily. Quote Link to comment Share on other sites More sharing options...
ThePoacher Posted February 6, 2022 Share Posted February 6, 2022 21 minutes ago, Redback said: Did see your post asking and considered 3d printing being the solution however. The heat might be a bit much unless you can get it printed in ABS PLA isnt suitable as its sensative to heat over 40c and possibly PETG isnt suitable as escs can get over 70c easily. Thanks for the reply. Yeah thats understandable with the heat etc. I have some ideas without the use of a 3d printer so ill trial and error and see how i go Quote Link to comment Share on other sites More sharing options...
