Flele Posted July 10, 2019 Share Posted July 10, 2019 Hello! I'm fairly new to the RC hobby but wanted to challenge myself. All the planning is finished now, so I'm just asking to check if I have remembered all the electronics: 2 Brushless Motors 2 Speed Controllers (ESC) 2 Batteries 7 Servos (2x Flaps, 2x Ailerons, 1x Rudder, 1x Elevator, 1x Gear) 1 Receiver 1 Transmitter 1 Servo Signal Reverser (For the rudder, because the technique I'll use will make it turn left when pushing right, vice versa) 1 SBEC Switch Regulator (For the receiver. The batteries provide to high voltage for the receiver to handle) Obviously I could've added retractable landing gear, but this is just a small model so I won't build that, yet ... The features I want in my plane are the following: Flaps, ailerons, rudder, elevator, two motors and steerable front landing gear. Do you think I should add lights to it too, or isn't it necessary for a little 2 kg model? Thank you. Quote Link to comment Share on other sites More sharing options...
tomzac66 Posted July 22, 2019 Share Posted July 22, 2019 That’s some kit for someone fairly new to the hobby.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
