Daveyb84 Posted June 17, 2015 Share Posted June 17, 2015 http://www.ebay.co.uk/itm/Original-iMAX-B6-RC-Lipo-NiMh-Battery-Balance-Charger-12V-5A-AC-Power-Adapter-/181486661013?pt=LH_DefaultDomain_3&hash=item2a4172ad95 comes with both Link to comment Share on other sites More sharing options...
Pathaleon Posted June 17, 2015 Share Posted June 17, 2015 If you intend to use a laptop charger make sure its between 11-18v though as most are normally 19v/19.5v Link to comment Share on other sites More sharing options...
everclear1984 Posted June 17, 2015 Share Posted June 17, 2015 If you intend to use a laptop charger make sure its between 11-18v though as most are normally 19v/19.5v I must have got lucky, I didn't check Link to comment Share on other sites More sharing options...
Relativenewbyseb Posted June 17, 2015 Share Posted June 17, 2015 With my imax I just bought both separately off eBay, charger 18 quid and power supply 5, dunno if it really matters if it's a fake as there are so many different rebrands of the same 4 button charger With regards lipo and added wear there will be no more on 2s as it's same voltage if not less if you're using 8.4 v nimh already Link to comment Share on other sites More sharing options...
evssv Posted June 17, 2015 Share Posted June 17, 2015 It's 3s lipos what will kill it quiker ... Link to comment Share on other sites More sharing options...
Noj Posted June 17, 2015 Share Posted June 17, 2015 its just that the rc is brushed so the lipos will wear it. Where have you read this? The ESCs in both the Firestorm 10t and Flux are lipo compatible. The can in the brushed version is perfectly suitable for lipo use; stock, brushed motors are not exactly high quality, cost very little to replace, which is moot if buying new, as HPI have an excellent warranty and customer service policy. As noted, the cost of lipo vs NiMH is negligible, charging equipment is not expensive, the lipo trumps NiMH for power delivery and runtime, every time. A BL set up without lipo is like curry without a tasty bread product and side dish, just not satisfying or cost effective.... 2 Link to comment Share on other sites More sharing options...
DannyP Posted June 17, 2015 Share Posted June 17, 2015 My son has 2s LiPo's for his brushed Firestorm THESE Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 18, 2015 Author Share Posted June 18, 2015 My son has 2s LiPo's for his brushed Firestorm THESE do i need to solder for them? Link to comment Share on other sites More sharing options...
Pathaleon Posted June 18, 2015 Share Posted June 18, 2015 They have 5.5mm bullets fitted if you read further down the spec for discharge plug Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 18, 2015 Author Share Posted June 18, 2015 They have 5.5mm bullets fitted if you read further down the spec for discharge plug Sent from my iPhone using Tapatalk that means?... Link to comment Share on other sites More sharing options...
Pathaleon Posted June 18, 2015 Share Posted June 18, 2015 If you have 5.5mm bullet connectors on your speed controller then this will plug straight in. If you don't which is likely then you will either need to chop off the battery one and change it or chop off the speed controller one and change it which does involve soldering. Link to comment Share on other sites More sharing options...
Noj Posted June 18, 2015 Share Posted June 18, 2015 ...or buy a convertor connector, unless a Tamiya plug is involved. Look at the lipos you intend to buy, swap the ESC connector to match, no more soldering needed. Soldering is an essential part of the hobby. In the short term, a local hobby shop or perhaps a forum member may be able to assist. Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 right... ive done some research for a bit and its out of these http://www.modelsport.co.uk/losi-mini-8ight-brushless-buggy-black-/rc-car-products/366368 http://www.modelsport.co.uk/hpi-e-firestorm-10t-rtr-2.4ghz/rc-car-products/380330 http://www.modelsport.co.uk/losi-mini-8-rtr-avc-1-14-4wd-buggy-black-in/rc-car-products/393455 What are the pros and cons of them which one is best for general bashing and speed runs what should i pick? Link to comment Share on other sites More sharing options...
evssv Posted June 20, 2015 Share Posted June 20, 2015 (edited) right... ive done some research for a bit and its out of thesehttp://www.modelsport.co.uk/losi-mini-8ight-brushless-buggy-black-/rc-car-products/366368 http://www.modelsport.co.uk/hpi-e-firestorm-10t-rtr-2.4ghz/rc-car-products/380330http://www.modelsport.co.uk/losi-mini-8-rtr-avc-1-14-4wd-buggy-black-in/rc-car-products/393455 What are the pros and cons of them which one is best for general bashing and speed runs what should i pick? surly u know the anwser to this Q by now? ? Edited June 20, 2015 by evssv Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 surly u know the anwser to this Q by now? ? lol i saw that losi yesterday and thought it looked epic, buggy which is my fave design, brushless, lipo compatible, metal diffs, 4wd Link to comment Share on other sites More sharing options...
evssv Posted June 20, 2015 Share Posted June 20, 2015 lol i saw that losi yesterday and thought it looked epic, buggy which is my fave design, brushless, lipo compatible, metal diffs, 4wd its small....wont go many places....the stock electrics arnt much cop.....get the fs and have done with it! !....lol! ! Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 its small....wont go many places....the stock electrics arnt much cop.....get the fs and have done with it! !....lol! ! it seems good enough for me Link to comment Share on other sites More sharing options...
evssv Posted June 20, 2015 Share Posted June 20, 2015 it seems good enough for me cool...buy one then...I know I`d rather take a firestorm over a mini losi8...more versitle....my boy sold his fs flux recently and I recently had a losi mni8t....I would pick the firestorm outa these 2.... 1 Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 cool...buy one then...I know I`d rather take a firestorm over a mini losi8...more versitle....my boy sold his fs flux recently and I recently had a losi mni8t....I would pick the firestorm outa these 2.... i will try to stop hassling you lol, this is my mates one and im only suggesting it as he has one, never had any problems and i had a go and it seemed quick for a stock rc http://www.modelsport.co.uk/traxxas-1-16-e-revo-xl-2.5-tq-2.4ghz-silver-/rc-car-products/379447 Link to comment Share on other sites More sharing options...
evssv Posted June 20, 2015 Share Posted June 20, 2015 (edited) i will try to stop hassling you lol, this is my mates one and im only suggesting it as he has one, never had any problems and i had a go and it seemed quick for a stock rc http://www.modelsport.co.uk/traxxas-1-16-e-revo-xl-2.5-tq-2.4ghz-silver-/rc-car-products/379447 lol!!....ur ok.. ..if ur mate has one. and ur happy with what u`ve seen of his then go for it....its ur descision at the end of the day....but I`d still take the firestorm tbh...will b a lot stronger then a losi mini of any type in stock form imo.. Edited June 20, 2015 by evssv Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 lol!!....ur ok.. ..if ur mate has one. and ur happy with what u`ve seen of his then go for it....its ur descision at the end of the day....but I`d still take the firestorm tbh...will b a lot stronger then a losi mini of any type in stock form imo.. yeah, my mate has one and we went around his area with it seemed quick. is there any failure points on them and should i get a better charger, included chargers are normally bad Link to comment Share on other sites More sharing options...
evssv Posted June 20, 2015 Share Posted June 20, 2015 (edited) yeah, my mate has one and we went around his area with it seemed quick.is there any failure points on them and should i get a better charger, included chargers are normally badnow u need to get in here for ur Q`s on minis..http://www.msuk-forum.co.uk/forum/3-micro-mini/..lipos...therse r good.. jus buy the same charger as u were gonna get for the firestorm... Edited June 20, 2015 by evssv Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 now u need to get in here for ur Q`s on minis..http://www.msuk-forum.co.uk/forum/3-micro-mini/..lipos...therse r good.. jus buy the same charger as u were gonna get for the firestorm... is that where i post about the 1/16 erevo then Link to comment Share on other sites More sharing options...
evssv Posted June 20, 2015 Share Posted June 20, 2015 (edited) is that where i post about the 1/16 erevo then lipos r from hobbyking... Edited June 20, 2015 by evssv Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 20, 2015 Author Share Posted June 20, 2015 lipos r from hobbyking... im not sure the brushed one supports lipo? Link to comment Share on other sites More sharing options...
