Dannymitchell506 Posted June 2, 2015 Share Posted June 2, 2015 How do you get a drive shaft out of the steering knuckle Quote Link to comment Share on other sites More sharing options...
chrisknights Posted June 2, 2015 Share Posted June 2, 2015 inside the wheel hex is a grub screw , undo that and then slide out the pin in the hex and then if will free the drive shaft Quote Link to comment Share on other sites More sharing options...
Dannymitchell506 Posted June 2, 2015 Author Share Posted June 2, 2015 I've took the grub screw out but I can't get the pin out? Any help Quote Link to comment Share on other sites More sharing options...
chrisknights Posted June 2, 2015 Share Posted June 2, 2015 slighty tap it out Quote Link to comment Share on other sites More sharing options...
