Bigjimknickers Posted July 22, 2016 Share Posted July 22, 2016 Yes me & Mydoddy have them fitted on ours. It is expensive, but I bought mine instead of a CNC spur so technically, I saved money! Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted July 22, 2016 Share Posted July 22, 2016 CNC spur is out of stock at CML, only £13 for the spur though. Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted July 22, 2016 Author Share Posted July 22, 2016 24 minutes ago, NuttyProfessor said: will it work with the leccy gearbox though? Bit steep at £40. Also fitted the second brace. Nice and solid. Here you go save yourself a tenner https://www.ebay.co.uk/itm/191418921345 you ou can use there website aswell for a couple more quid off http://www.rc-willpower.com/Cart/index.php?route=product/product&path=145_216_259&product_id=28509&limit=100 Or PM Nige at freespawn he might be able to do you a good deal Quote Link to comment Share on other sites More sharing options...
dazp1976 Posted July 22, 2016 Share Posted July 22, 2016 On 7/20/2016 at 19:21, mydoddy69 said: Nice little deal just popped up on eBay might suit someone looking for one of these https://www.ebay.co.uk/itm/131882346658 If someone was keen to split 3 of my 6s bricks down to 2x 3s for me I might be persuaded 1 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted July 22, 2016 Author Share Posted July 22, 2016 Just now, NuttyProfessor said: CNC spur is out of stock at CML, only £13 for the spur though. Lol if you want a spur let me know I got one sat here Pm me for details Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted July 22, 2016 Author Share Posted July 22, 2016 2 minutes ago, dazp1976 said: If someone was keen to split 3 of my 6s bricks down to 2x 3s for me I might be persuaded Ask Bez he has a service for RC repair I'm sure he will be happy to sort them out Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted July 22, 2016 Share Posted July 22, 2016 I did try 2 6s bricks in parallel, brought the CoG down lower and balanced it towards the front when I took the battery boxes off and just used the Velcro, since put the boxes back and use 2x3s for mental runs. Mainly run on 4s though. I'm used to speed with handling, not speed and oh **** its on its roof again! Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted July 22, 2016 Share Posted July 22, 2016 as I wasn't happy with the wheelie bar height, got some 3mm thick metal restraint lengths and cut 2 pieces to drop the wheel around 2 inches lower, less than a 45 degree angle on full lift now. Quote Link to comment Share on other sites More sharing options...
Devin Posted July 26, 2016 Share Posted July 26, 2016 So has anyone had issues with the wheel Hex pin? The one that goes through Hex and axel I've just to mine off to do some bearing maintainance and found 2 of mine were shattered Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted July 26, 2016 Author Share Posted July 26, 2016 2 minutes ago, Devin said: So has anyone had issues with the wheel Hex pin? The one that goes through Hex and axel I've just to mine off to do some bearing maintainance and found 2 of mine were shattered Sent from my SM-G935F using Tapatalk Do you mean the grub screw pin ? cant say ive had a problem with mine to be honest, maybe its because you dont have the wheel locking bolt in ?? 1 Quote Link to comment Share on other sites More sharing options...
Devin Posted July 26, 2016 Share Posted July 26, 2016 Do you mean the grub screw pin ? cant say ive had a problem with mine to be honest, maybe its because you dont have the wheel locking bolt in ?? Yep that's the one doddy to be honest the amount of times I have done flips, jumps etc with throttle it had to happen some time but got new set coming in so will be sorted soon Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted July 27, 2016 Author Share Posted July 27, 2016 Ha ha finally got my hands on a set of these new cvd's sadly the outdrive cups are still in transit but should be here in the next few weeks so I'm going to hold off fitting these until they arrive .. They do feel a lot stronger and look better made with added thickness on the shafts .. If they go well up front I think I shall invest in a set for the rear as well .. 1 Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted July 29, 2016 Share Posted July 29, 2016 Mte plus posing today... 3 Quote Link to comment Share on other sites More sharing options...
NG15 Posted July 29, 2016 Share Posted July 29, 2016 Looks great that, the plus body is 1000x better that the original Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted July 29, 2016 Share Posted July 29, 2016 Looks smart mate. Proper MONSTER TRUCK lol. Quote Link to comment Share on other sites More sharing options...
dazp1976 Posted July 29, 2016 Share Posted July 29, 2016 (edited) On 7/26/2016 at 12:36, Devin said: Yep that's the one doddy to be honest the amount of times I have done flips, jumps etc with throttle it had to happen some time but got new set coming in so will be sorted soon Sent from my SM-G935F using Tapatalk What thickness is it, 3mm? I get something like this and chop it up. I get a fair few pins out of it for hexes and diff internals http://www.ebay.co.uk/itm/281124500837?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT If you think it's a good option then Steel / mild steel etc. Don't try titanium, it shatters. Edited July 29, 2016 by dazp1976 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted August 1, 2016 Author Share Posted August 1, 2016 Had mine out this morning whilst walking the dog boy I love this thing no drivetrain to constantly worry about its fast reliable and don't half jump bad either Im hoping my new outdrives will be here soon and I can get these new cvd's fitted up as I don't want to use them on the old ones. Think ill just use this now for a while and forget about the crappy X Maxx until there's some better ring and pinions out either that or sell the pile of turd Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted August 1, 2016 Share Posted August 1, 2016 Took mine out again yesterday, all I need now is some ramps & it'll be awesome! Loving mine, & boy is it quick, it's so fast that I nearly ran myself over with it yesterday, after I mis judged a turn & whacked the power on! Quote Link to comment Share on other sites More sharing options...
Twist Posted August 3, 2016 Share Posted August 3, 2016 (edited) Hmmm, this or TT MT4 G3 which is approx £70 cheaper. Edited August 3, 2016 by Twist Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted August 3, 2016 Share Posted August 3, 2016 19 minutes ago, Twist said: Hmmm, this or TT MT4 G3 which is approx £70 cheaper. I had the exact same question last month. This won. mydoddy will be along soon, I'm sure he'll agree, he has both & can give you views on both. Quote Link to comment Share on other sites More sharing options...
Devin Posted August 3, 2016 Share Posted August 3, 2016 I personally think the mt4 needs more bits to get it to the point of the Hyper although both do need work done to make them the best they can be Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted August 3, 2016 Author Share Posted August 3, 2016 4 hours ago, Twist said: Hmmm, this or TT MT4 G3 which is approx £70 cheaper. I have both and the £70 extra is money well spent IMO Mt4 parts are hard to find in the uk unless you use the eBay chop shops the MTe parts can be had from a variety of uk based shops, both need a few tweaks but I'd say the mte needs far less IMO Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted August 3, 2016 Share Posted August 3, 2016 Buuuuut.... remember the Mte also needs a wheelie bar/brace/slipper unit ideally, this is an extra £50+ on top of the £430 that should really be factored in straight away. Quote Link to comment Share on other sites More sharing options...
Twist Posted August 3, 2016 Share Posted August 3, 2016 32 minutes ago, Bigjimknickers said: Buuuuut.... remember the Mte also needs a wheelie bar/brace/slipper unit ideally, this is an extra £50+ on top of the £430 that should really be factored in straight away. Back to plan A then. Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted August 6, 2016 Share Posted August 6, 2016 ive wreaked my pinion and spur, full power on 6s, lost brakes so thought ah well, pinion has spun off but no, new pinion and spur needed. Quote Link to comment Share on other sites More sharing options...
