my alza xl savvy....
evssv
They hold quite well to be honest, just watch the front/rear diffs on hard landings...make sure you stay off the throttle
sound...i have checked and filled both of them and there sweet...For now.so new gear off ebay me thinks...i got a full being kit coming off Saabmania2 si might wait until they turn up and replace all of them...seein as there 2 years old. .if not older.. Edited by evssv
Tug will be unfamiliar with the stock alloy gear that came with the older flux's....you went straight to CD didn't you?
Stock alloy gear was prone to spontaneous disappearance, the older HP's came with a hardened one, about
The housing wont be deformed it will be the bearings that shot fella and yes when them bearings go spectacular things happen :D ive had a couple of failures myself ive lost a whole gearbox of tears due to them bearings collapsing
the bearings at the top r ok..no play in them...but I got full set on the way from saabmania so will replace the lot...should there b any play on the bottom shaft.. theres a pic on the page before this one..
