.AJ. Posted August 6, 2014 Author Share Posted August 6, 2014 Obviously they add extra maintenance, but that suits me fine, I've been warned the front pucks could be worn out in under 20 packs, but I've got 5 full sets in spares already, but the rears should do 50+ easily Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted August 6, 2014 Share Posted August 6, 2014 I don't mind the extra maintenance, it'd just be the initial testing so I could see how long a set of the pucks would last in a 2wd. It is a great idea though and I will most likely try a kit out at some point. One drawback is they only have outdrives for the ball diff, not the gear diff, but they may develop them if enough demand. Quote Link to comment Share on other sites More sharing options...
Alex97 Posted August 6, 2014 Share Posted August 6, 2014 (edited) I don't mind the extra maintenance, it'd just be the initial testing so I could see how long a set of the pucks would last in a 2wd. It is a great idea though and I will most likely try a kit out at some point. One drawback is they only have outdrives for the ball diff, not the gear diff, but they may develop them if enough demand. iv ran around 30 packs though my b5m so far and there isn't any wear so far. don't forget we run a lot less power than an 4wd sct. sorry for going off topic aj Edited August 6, 2014 by alex97 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 6, 2014 Author Share Posted August 6, 2014 Yea they should last longer in a 2wd, but these use larger Pucks so they should last ok, its just extreme drive shaft angle which kill them quicker and I've been told to keep them grease up with either Moly or Silicone based grease, I've used some 30k diff oil I found on mine Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 20, 2014 Author Share Posted August 20, 2014 Got her to the track today I couldn't be more happy with the way she is running and my set up is working really well, I've also booked her in for the SC class in the Apex GP in September Quote Link to comment Share on other sites More sharing options...
Alex97 Posted August 20, 2014 Share Posted August 20, 2014 That track looks great fun, your lucky to have unlimited access to it. Good luck at Apex in September 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 20, 2014 Author Share Posted August 20, 2014 Doh! Must have done it bashing at FOS, nevermind I've ordered a new tower from a US chop shop on eBay, Quote Link to comment Share on other sites More sharing options...
DazzaClio Posted August 21, 2014 Share Posted August 21, 2014 I was just going to ask how did it hold up at the weekend, a cheap fix though. Did it see quite a lot of use at the weekend? Thanks. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 21, 2014 Author Share Posted August 21, 2014 She held up fine apart from the crack in the tower, I must have done around 10 packs through her and she was chucked off the big ramp we had a few times, but it was bloody windy all weekend so some of landings were a bit messy, the white shell is a bit battered now lol Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted August 21, 2014 Share Posted August 21, 2014 Looking good but where's your lipo charge sack? haha Not so good about the shock tower. How you getting on with the new charger? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 21, 2014 Author Share Posted August 21, 2014 (edited) I use a sack if I'm at a club or at home, can't be arsed when bashing lol The charger does everything it should do, at 10a I'm turning around my 7600mah packs in about 25mins after a 7min run, so that's spot on for unstressed racing Edited August 21, 2014 by .AJ. Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted August 21, 2014 Share Posted August 21, 2014 I recently started using saddle packs for the first time, what a pain they are to get into a sack. Our club is quite strict about lipos being in a sack when charging. Sorry a bit off topic, but have you use a Team Orion Advantage ONE Duo charger? That's the other charger I've been looking at so I can charge two batteries. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 21, 2014 Author Share Posted August 21, 2014 Just looked at the spec of that Orion charger and it looks really good Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 22, 2014 Author Share Posted August 22, 2014 Got some more tyres fitted up this morning Quote Link to comment Share on other sites More sharing options...
charlesk Posted August 22, 2014 Share Posted August 22, 2014 (edited) My favourite 4wd dry astro/grass tyre. What inserts have you used,the stock orange ones I find a bit soft, the older green ones where fine... Suspect you might end up trimming the fronts down a bit. Edited August 22, 2014 by charlesk Quote Link to comment Share on other sites More sharing options...
mugen mark Posted August 22, 2014 Share Posted August 22, 2014 have your pliers ready for the reedy gp,those tyres look like grip roll city. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted August 22, 2014 Author Share Posted August 22, 2014 The Kourse Kings are more for our track which has longer Astro, at SHRCCC I'll run Nanobytes, they work bloody awesome on short pile Astro/carpet Quote Link to comment Share on other sites More sharing options...
