BanditBuggy Posted August 21, 2013 Share Posted August 21, 2013 Can someone recomend a good fan for this type of motor? Quote Link to comment Share on other sites More sharing options...
suicideneil Posted August 21, 2013 Share Posted August 21, 2013 Can someone recomend a good fan for this type of motor? You don't need one if you are geared correctly, and besides, a tiny little fan won't make any real difference to the temps inside the motor; all you will be doing is masking the problem, not fixing it. I'd suggest you look into the Hobbywing system as you were advised in your other thread- plenty of 65-80amp esc & 36x50mm motors in the 3000-4000kv range to look at which are more powerful, cooler running & half the price.... Quote Link to comment Share on other sites More sharing options...
barnetbasher Posted August 21, 2013 Share Posted August 21, 2013 how to put a plaster over gangrene ! 1 Quote Link to comment Share on other sites More sharing options...
BanditBuggy Posted August 21, 2013 Author Share Posted August 21, 2013 Ok Quote Link to comment Share on other sites More sharing options...
