zlab Posted March 21, 2021 Share Posted March 21, 2021 (edited) 7 minutes ago, Iain .R said: A new message from the carnage man lol I have finally fitted the 2an motor and done the esc and it's all working Things left to finishe Wait for new upper plate to arrive bought today . Arrival of battery tray back order .. Then bash time and post the crazy vid as I had a drive forward last night and it seems fast . One thing Does anyone know the bounch strength of the carnage shocks and what shock are stronger iv changed the oil but still bit soft cheers hardness of the suspension depends mostly on the spring. With oil you set the damping. I use the 400cst oil and it works ok with stock springs did you completely dissasemble the shocks? I had a problem some time ago on the carnage that on one of the rear shocks e-clip felt of, resulting in absolutely no damping of the shock, as the piston was no more connected to the shaft... Edited March 21, 2021 by zlab Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 21, 2021 Share Posted March 21, 2021 Hi I'm not sure I'll have to check but off the top I think 500 .I have a look when iget home . I need more spring more push buck up .as iv added a bit more weight to the car I need more lift Is there a guild to how much spring Bounce resistance shocks/ springs have . Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 21, 2021 Share Posted March 21, 2021 5 minutes ago, zlab said: hardness of the suspension depends mostly on the spring. With oil you set the damping. I use the 400cst oil and it works ok with stock springs did you completely dissasemble the shocks? I had a problem some time ago on the carnage that on one of the rear shocks e-clip felt of, resulting in absolutely no damping of the shock, as the piston was no more connected to the shaft... Hi . Yea if been messing with my shocks as I had problems with a brand new car i bought there was no oil in the shocks at all as it leaked out so now I check them . As i said due to the car being hevery than stock I need more lift and heavy lift than stock . But I dont want mega expensive ones I guess hobbywing make type shocks before anyone says lol Quote Link to comment Share on other sites More sharing options...
Redback Posted March 21, 2021 Share Posted March 21, 2021 No hobbywing dont make shocks, you should just need some stronger rate spings, I use 1/8th scale hobao buggy springs, they fit on the shocks just fine. 2 Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 21, 2021 Share Posted March 21, 2021 17 minutes ago, Redback said: No hobbywing dont make shocks, you should just need some stronger rate spings, I use 1/8th scale hobao buggy springs, they fit on the shocks just fine. Cheers . M8 . There is was about to buy a hobbywing too lol Quote Link to comment Share on other sites More sharing options...
Ant.p Posted March 21, 2021 Share Posted March 21, 2021 I’ve just given my shock an overhaul. Completely stripped down and cleaned. min the process I discovered a slightly bent piston so straightened it again before reconstructing after watching countless videos on how best to do it. I used original springs but 50wt oil. Haven’t had a chance to test it ‘on the road’ as waiting for other parts still, but I have noticed an improvement with the car just standing still. Much better rebound now and freed up all the joints that are meant to allow movement in the suspension arms at the same time. the car rests about 2/3 full height of dampers, which I’m pretty happy with, and there’s plenty of adjustment left to increase the ride height if needed. Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 21, 2021 Share Posted March 21, 2021 Yea its 500 oil I have . Quote Link to comment Share on other sites More sharing options...
Ant.p Posted March 21, 2021 Share Posted March 21, 2021 4 minutes ago, Iain .R said: Yea its 500 oil I have . mine is 650cst, 50 wt. A little thicker than yours. I was hoping that this will help absorb some of the shock on impact, as before with the original 30wt the shocks were bottoming out with the springs wound right down. The car used to be bouncy but with little dampening - hope I haven't sent it the other way 🙏 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted March 22, 2021 Share Posted March 22, 2021 has any one fitted a different bodyshell to the vantage....i could use a bit more room under the shell Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 23, 2021 Share Posted March 23, 2021 Hi guys I need some info on the 20A esc on the carnage will 2 of these take a 3s lipo battery . Its for the !! mega carnage !! It's time to power it . So I need to know if any you guys uses a 3s lupo on the brushed carnage 20A esc as it's now two 20A esc so is it now a 40A ???? Plz replies as soon as you can as I need to see about buying the battery off here . Cheers Quote Link to comment Share on other sites More sharing options...
James.S Posted March 23, 2021 Share Posted March 23, 2021 @Iain .R I wouldn't recommend it mate. I don't think those will handle 3s at all. They might die instantly when you plug in the battery. Just run 2s for now and upgrade to at least a 60A ESC, preferably 80A, if you want to run 3S reliably. 1 Quote Link to comment Share on other sites More sharing options...
Redback Posted March 23, 2021 Share Posted March 23, 2021 (edited) indeed and to add afaik thats not how it works 2x 20amp escs connected to diffrent motors is still a 20a esc dont connect your escs motor leads together to increase the power. But keep having fun tinkering and experimenting, looking forward to seeing the "mega carnage" Edited March 23, 2021 by Redback 1 1 Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 23, 2021 Share Posted March 23, 2021 55 minutes ago, James.S said: @Iain .R I wouldn't recommend it mate. I don't think those will handle 3s at all. They might die instantly when you plug in the battery. Just run 2s for now and upgrade to at least a 60A ESC, preferably 80A, if you want to run 3S reliably. I'm still working on funds to get a single esc which will be more A I cant remember what one it is . But the 2 i have are just spears . Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 23, 2021 Share Posted March 23, 2021 48 minutes ago, Redback said: indeed and to add afaik thats not how it works 2x 20amp escs connected to diffrent motors is still a 20a esc dont connect your escs motor leads together to increase the power. But keep having fun tinkering and experimenting, looking forward to seeing the "mega carnage" Hi as for the 2 esc just reading it now it was like doh really ????? As it's still one esc one motor . Iv used a Y spliter to run both esc out of the reciver . I just taken out one red cable on one esc . The both wheels run and steers I just have to turn on two on/off switches . I was going to join both on /off switch together but I turned the back wheels off and just had front wheel drive and it was like drift car on the kitchen floor lol Just taken 20mins to get the marks out the wood flooring. But almost all gone now . 1 Quote Link to comment Share on other sites More sharing options...
Redback Posted March 23, 2021 Share Posted March 23, 2021 2 minutes ago, Iain .R said: Hi as for the 2 esc just reading it now it was like doh really ????? As it's still one esc one motor . Iv used a Y spliter to run both esc out of the reciver . I just taken out one red cable on one esc . The both wheels run and steers I just have to turn on two on/off switches . I was going to join both on /off switch together but I turned the back wheels off and just had front wheel drive and it was like drift car on the kitchen floor lol Just taken 20mins to get the marks out the wood flooring. But almost all gone now . I dont want to derail the thread so maybe you could make a thread about your mega carnage, but to say when you run two motors like this they need to run at the same speeds to ensure they dont cause issues. Heres a complicated video explaining the above. 1 Quote Link to comment Share on other sites More sharing options...
Ant.p Posted March 23, 2021 Share Posted March 23, 2021 16 minutes ago, Redback said: Heres a complicated video explaining the above. 🤯 ay caramba! Quote Link to comment Share on other sites More sharing options...
Savagebrum Posted March 24, 2021 Share Posted March 24, 2021 Have been away from rc for a while after having a son he is finally big enough to hold a controller and has enjoed a few runs of my scx10, but i want to get him something a bit quicker and think he will enjoy it more. After much searching and thinking what to get for him to try, I came across this thread. The brushed vantage looks a great choose. Thanks for all the info here 1 Quote Link to comment Share on other sites More sharing options...
Jens Posted March 24, 2021 Share Posted March 24, 2021 6 minutes ago, Savagebrum said: Have been away from rc for a while after having a son he is finally big enough to hold a controller and has enjoed a few runs of my scx10, but i want to get him something a bit quicker and think he will enjoy it more. After much searching and thinking what to get for him to try, I came across this thread. The brushed vantage looks a great choose. Thanks for all the info here Hi and welcome back. Yes, some of us have been very busy here writing a lot in the past few months. ( Probably due to too much homeoffice ) And a good choice for your son. 1 Quote Link to comment Share on other sites More sharing options...
Savagebrum Posted March 24, 2021 Share Posted March 24, 2021 Thanks I'm sure I'll enjoy it too lol. just got to stop myself for going brushless before he can drive Quote Link to comment Share on other sites More sharing options...
Ant.p Posted March 24, 2021 Share Posted March 24, 2021 6 hours ago, Savagebrum said: Thanks I'm sure I'll enjoy it too lol. just got to stop myself for going brushless before he can drive We all know it’s for you really 🤫😆 1 Quote Link to comment Share on other sites More sharing options...
Savagebrum Posted March 25, 2021 Share Posted March 25, 2021 Haha so true Quote Link to comment Share on other sites More sharing options...
Carlos1988 Posted March 26, 2021 Share Posted March 26, 2021 What diff oil are ppl using here in carnage, I have 7000 in rear and putting 10000 in the front..just wondered what other people use Quote Link to comment Share on other sites More sharing options...
Carlos1988 Posted March 26, 2021 Share Posted March 26, 2021 Also if diff oil is the way to go with these as I see many people just using greese Quote Link to comment Share on other sites More sharing options...
Iain .R Posted March 26, 2021 Share Posted March 26, 2021 26 minutes ago, Carlos1988 said: Also if diff oil is the way to go with these as I see many people just using greese If you use oil it just all run out??? Quote Link to comment Share on other sites More sharing options...
zlab Posted March 26, 2021 Share Posted March 26, 2021 I use 30k cst rear and 70k in the front. It works great. I added some shims on the output shaft, so the o-ring is tight in there (didn't even try without it, so i can't tell if it leaks without this). I am also using automotive gasket maker in between the housing and spur gear. Never had any leak problems... Quote Link to comment Share on other sites More sharing options...
