jammi Posted August 31, 2009 Share Posted August 31, 2009 (edited) when is the above comming out really want to get that "New from Axial: SCX10 TR (Trail Ready) Complete ready to run out of the box 4WD 27T Electric Motor: Tear up the terrain in-door or out-doors. Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go! 20T pinion paired with an 87T spur gear gives you quick acceleration while still allowing for a smooth low end speed range True Beadlocks: No Messy Glue! Hi-quality Composite Plastic and Metals 6 LED's: 4 white LED’s for the front and 2 red LED’s for the rear Electronic Speed Controller (ESC): forward and reverse speed controller. Hi-Torque metal gear servo helps hold your line when rock crawling Solid Rear Axle lockouts improve ground clearance and offer a more realistic appearance Slipper Clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain. Steel chassis rails with a molded composite plastic cross members provide a solid and rigid chassis Ultra compact and lightweight transmission Full Ball bearings Overall gear ratio range from 15:1 to 74:1 Transmission: 2.6:1; center mounted Tires: Pro-Line 1.9 Flatirons tires Wheels: Axial 1.9 8 Hole Beadlocks (Satin Chrome) Suspension: 3 Link Drive Shafts: Universal front and rear " Edited August 31, 2009 by jammi Quote Link to comment Share on other sites More sharing options...
53HRA Posted August 31, 2009 Share Posted August 31, 2009 I think its due soon Shame about the 27T motor in my opinion...far to fast for a crawler Axial should of put there 55T motor in there Quote Link to comment Share on other sites More sharing options...
