Fly In My Soup Posted December 3, 2016 Author Share Posted December 3, 2016 6 hours ago, atom3624 said: 1000 wt or 1000 CST? Not sure, chucked empty bottle! I think it was core rc Quote Link to comment Share on other sites More sharing options...
atom3624 Posted December 4, 2016 Share Posted December 4, 2016 'Googling' for 2 minutes I determined Core RC shock oil is in CST. Also that 1000 is approximately 80 wt Associated shock oil. That is pretty thick but not for Largescale FG's, for example. 'Best Fit' for the FG MT was ~1500 - 2500 CST, most defaulting to ~2000. Al. 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 4, 2016 Author Share Posted December 4, 2016 1 hour ago, atom3624 said: 'Googling' for 2 minutes I determined Core RC shock oil is in CST. Also that 1000 is approximately 80 wt Associated shock oil. That is pretty thick but not for Largescale FG's, for example. 'Best Fit' for the FG MT was ~1500 - 2500 CST, most defaulting to ~2000. Al. Ahh ok. Thanks al. I'm ordering more as we speak! Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 4, 2016 Author Share Posted December 4, 2016 Arghh, she started bogging again this morning, so took her home, stripped the carb off etc, found a gasket had shifted to cover the lower fuel entry hole. Sorted the gasket, and re assembled, now she won't start lmao! She getting good spark, plug is wet when taken out so fuels getting through. I dry the plug out, flip it upside down etc etc to unflood lower end, put plug back in, still nothing! I'm stumped now, she's getting fuel, can't see any air issues, and she's getting spark. But no fire! Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 8, 2016 Author Share Posted December 8, 2016 (edited) Found issue on weekend, another failed gasket, this time on the head side if tge isolator block. Ordered complete gasket set this time, still waiting for it to arrive. Was posted from the Midlands on Monday first class!! I think the Postie's should get some of these instead of their slow vans..... Edited December 8, 2016 by Fly In My Soup 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 11, 2016 Author Share Posted December 11, 2016 Argh she still wont start/run properply. She will start if wot applied, and stays applied, she's not reaching full rpm for the clutch to even engage properly, then when throttle let off she just dies, she's also firing fuel into air filter, not a lot by any means, a mild residue, but I'm assuming this is from starting at wot Here's what I've tried so far; • stripped carb, spraying with c.cleaner, cleaning all jets, etc • re gapped coil • changed spark plug for new, checked spark. • fitted new carb gaskets, air and both sides of isolator block,checke pulse hole is clear • torqued engine head bolts up to super tight, they Weren't loose anyway • tried starting with air filter removed, then exhaust removed. She seems to have great compression, although I do not have a compression tester. I would say head gasket, however she did run great with these gaskets, started etc etc not a problem. It was as she was doing v.gentle runs, she started to bog on throttle, then just refused to start properly May just purchase a new carb to eliminate that first, then try engine gaskets after that Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 11, 2016 Author Share Posted December 11, 2016 P.s plug is wet when removed Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 14, 2016 Author Share Posted December 14, 2016 Already posted this on a different thread, but it turned out to be a worn/shifted piston ring, causing crap comp. Seal and blow by Will update when they arrive!! Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 18, 2016 Author Share Posted December 18, 2016 Piston kit arrived today, was OK to fit, took around 30 minutes. Compression feels much better now, will fit exhaust Tomorrow, then its time for a test. Should do a brief run in for new piston/ring ?? Thought I'd fit this 2 stage filter, waiting for outerwear though, so for now she wears the k+n with shroud Quote Link to comment Share on other sites More sharing options...
Scotty napalm Posted December 18, 2016 Share Posted December 18, 2016 Alright mate, yeah just do a brief break in. We're you get that piston from that head looks a bit ruffSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 18, 2016 Author Share Posted December 18, 2016 Fleebay matey, cheapie one!!! Its just the light I think !? When I compared it to zen/xmax head it looks same, whether they've had replacements I'm not sure. Just a thought, seeing as you mentioned it, can you buy smooth ones, or modify it to be smooth, I.e sand and Polish? 3 hours ago, Scotty napalm said: Alright mate, yeah just do a brief break in. We're you get that piston from that head looks a bit ruff Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Scotty napalm Posted December 18, 2016 Share Posted December 18, 2016 CAN polish them up a bit mate. What size piston is it? Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 18, 2016 Author Share Posted December 18, 2016 (edited) 36mm with 30mm stroke Which I believe makes it a 30.5 cc Xmax only sell two engines, 29 and 30.5 so it narrowed it down, plus I had help converting the bore to cc from dudes on here. So I guest this would make this the fastest kyosho arc ever built, lmfao Edited December 18, 2016 by Fly In My Soup Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 18, 2016 Author Share Posted December 18, 2016 35 minutes ago, Scotty napalm said: CAN polish them up a bit mate. What size piston is it? Sent from my iPhone using Tapatalk May have a go with my buffer later, I wanna see if it runs first!!!! Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 18, 2016 Author Share Posted December 18, 2016 Rebuilt her, no joy, then fitted a entirely new carb ( had previously tried a used spare, and rebuilt +recleaned the original), she fired right up!!! Video eta tomorrow afternoon!!! P.s Christ this pipe is loud, it gives a nice throaty cracking pop on idle, a lot louder than the samba. Its an fg big power pipe 5-038/dmc 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 19, 2016 Author Share Posted December 19, 2016 So took her out for a brief run in today, as per scotty's advice, so did two heat cycles on 1 full tank. scary power indeed.. Will be making video tomorrow of a full run ... Finally!!! Made a new carbon piece up for the gear guard for tomorrows run Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 19, 2016 Author Share Posted December 19, 2016 (edited) Thought you guys would appreciate the car that the arc and fg narder where based upon. Its a big Yankee Cross control from 1987 Edited December 20, 2016 by Fly In My Soup 2 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 20, 2016 Author Share Posted December 20, 2016 Raining, no video today! Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 22, 2016 Author Share Posted December 22, 2016 I managed to get out today and do a few very short vids on the way home from mundane Xmas extended relative duties... Just wanted you guys to see it in action, however brief or crap the vid is. Let me apologise for the crap res on the footage, borrowed my sons tablet to take these, cant wait till new year to take some good vids( Santa's bringing my son a 1080p action cam with live stream etc etc ) Just finished a mini break in of new piston/ring so didn't want to gun it too much, tires/wheels are letting it down big time I think, sturggling to transfer power, she's nearly destroying them (the foams have gone inside now as well) Anyone know a good set of 17mm MT w/tires around????? criteria is 17mm hex and o.diameter of min.150mm 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted December 27, 2016 Author Share Posted December 27, 2016 (edited) Another quick video to test the arc and also a new cam. Apologies for slightly hazy focus, I forgot to switch the autofocus on She cuts out when the exhaust is plugged with crud after second wheelie Edit, second video taken today. Final test run, got to open her up a bit more, I have noticed after fitting new carb that the carb butterfly isn't opening all the way, so will adjust servo arm sweep on the throttle side only so carb butterfly is 100% open instead of 90%. So may see some more power yet! Bid also ends with exhaust silicone tearing, so will have to use the dh Motorsport one ( excellent quality ) that I earmarked for the harm bx1. Edited December 29, 2016 by Fly In My Soup 1 Quote Link to comment Share on other sites More sharing options...
