XV Pilot Posted December 23, 2016 Share Posted December 23, 2016 There is nothing stopping you from using a nut with it if you want to, but it isn't necessary. The bolt would thread through the hole in the plastic steering arm from the bottom, then you'd slide your washers or spacer onto it from above, then top it off with one of the internally threaded 5mm ball connectors you linked to earlier. 1 Quote Link to comment Share on other sites More sharing options...
BlackHole Posted December 23, 2016 Author Share Posted December 23, 2016 https://www.modelsport.co.uk/screws/rc-car-categories/9970/998085&MSAttributeID[74]=791&MSAttributeID[76]=1089 Will this be a fittable screw? I'm guessing M3 means 3mm? Quote Link to comment Share on other sites More sharing options...
XV Pilot Posted December 23, 2016 Share Posted December 23, 2016 Yes, those will do the trick. Quote Link to comment Share on other sites More sharing options...
