conchp Posted February 28, 2015 Author Share Posted February 28, 2015 hmmm whats the pulse port and hmm ill have a look Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 and the fuel cap thing? i dont understand what you mean mate Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 carb gasket on the right way round and not blocking the pulse port? hmm what is this? Quote Link to comment Share on other sites More sharing options...
flatout! Posted February 28, 2015 Share Posted February 28, 2015 There'sa rubber bung Iinside your fuel cap what john was on about from rc modelz, if the hole is bunged up it want be able to breath properly or not at all, take your cap off have a look inside, the rubber bung will have a hole in it, make sure you can blow through it, and the cap to 1 Quote Link to comment Share on other sites More sharing options...
mark35 Posted February 28, 2015 Share Posted February 28, 2015 If your plugs dry put a couple of drops of fuel in the spark plug hole refit plug an give it a pull with no choke, should at least fire then. Quote Link to comment Share on other sites More sharing options...
flatout! Posted February 28, 2015 Share Posted February 28, 2015 And id check the hmm and make sure the hmm is ok, lol! Pmsl! Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 there is no ring plastic fule cap? ahahaha and petrol seems to be more inside the air filter ahaha Quote Link to comment Share on other sites More sharing options...
flatout! Posted February 28, 2015 Share Posted February 28, 2015 Sorry pal i was joking with the hmm 's, there isn't a rubber bung in the cap,? have you got a breather pipe on the filler cap then Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 even with fuel in the head it has no signs of life Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 new to petrol mate, half these things ive no idea about, can you provide pics or anything of what you mean? Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 i did remove the primer bulb also and the white part under it, could this be stopping it? Quote Link to comment Share on other sites More sharing options...
flatout! Posted February 28, 2015 Share Posted February 28, 2015 Im on about the fuel cap on your fuel tank? If you've removed these parts from your carb then i hope you've put them back, stick some pictures of your situation on pal, Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 just checked, the carbs fine. there is no rubber ring in the fuel cap at all Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 ive tried this so far new head new piston rings New gaskets set the coil housing above flywheel with card new plug Bit of fuel in head open throttle when starting checked for spark (there is) engine is all assembled properly The plug dosnt seem wet with fuel nothing happens when choke down or up just a smell of petrol Quote Link to comment Share on other sites More sharing options...
mark35 Posted February 28, 2015 Share Posted February 28, 2015 (edited) Just leave your plugout over night an give it a go tomorrow. It's deffo gettin fuel if it in the air filter, might be flooded. with all them pats fitted I'd be expecting it to start after a few pulls. Edited February 28, 2015 by mark35 2 Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 ok mate Quote Link to comment Share on other sites More sharing options...
conchp Posted February 28, 2015 Author Share Posted February 28, 2015 i know anything that would stop it starting? if everything was fine ? will the swich on the engine missing the connector stop it ? even with fuel in the head ive no luck Quote Link to comment Share on other sites More sharing options...
evssv Posted March 1, 2015 Share Posted March 1, 2015 (edited) i know anything that would stop it starting? if everything was fine ? will the swich on the engine missing the connector stop it ? even with fuel in the head ive no lucku r setting the kill switch to start arnt u??the switch on the tx handal??.. Edited March 1, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
conchp Posted March 1, 2015 Author Share Posted March 1, 2015 yeah hahaha Quote Link to comment Share on other sites More sharing options...
evssv Posted March 1, 2015 Share Posted March 1, 2015 fair nuff..... Quote Link to comment Share on other sites More sharing options...
