ollietheox Posted May 11, 2013 Share Posted May 11, 2013 Stripped some gear on my S28. Replaced the worn parts, but now only have forward drive and no reverse (and before anyone says about not needing reverse........you haven't seen my driving). Anyone ever come across this or know what I've done wrong? Everything seems to have gone back in the right place, just cant engage reverse. Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
walters Posted May 11, 2013 Share Posted May 11, 2013 (edited) is that the thunder tiger monster truck i use to have one it was my drive pin were snaping Edited May 11, 2013 by walters Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 11, 2013 Author Share Posted May 11, 2013 Yep Quote Link to comment Share on other sites More sharing options...
walters Posted May 11, 2013 Share Posted May 11, 2013 check your drive pins mate Quote Link to comment Share on other sites More sharing options...
jordan_bench10 Posted May 11, 2013 Share Posted May 11, 2013 Common fault drive pins or the adhustment isnt set right Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 11, 2013 Author Share Posted May 11, 2013 All pins present and correct and re-thread locked. Quote Link to comment Share on other sites More sharing options...
Rich8 Posted May 11, 2013 Share Posted May 11, 2013 First check if you can engage reverse by sliding the selector arm by hand. If it engages by hand, then it's just your aux servo not doing as it's told, or the linkage nneeds adjusting. If it won't engage by hand then you might have to take the gearbox apart again to investigate. Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 11, 2013 Author Share Posted May 11, 2013 That's the problem, cant slide it by hand. Had it open twice and cannot for the life of me figure out what's wrong. Quote Link to comment Share on other sites More sharing options...
Arron421 Posted May 12, 2013 Share Posted May 12, 2013 s28 gearbox is a waste of time will just keep happening. save your money and buy the s50 one will have no issues. Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 13, 2013 Author Share Posted May 13, 2013 If I had 70 bucks to spend on an S50 box, then I would. Considering the gears are only 5 bucks to replace, think I'll stick to tearing out what little hair I have left. Quote Link to comment Share on other sites More sharing options...
MrPug Posted May 13, 2013 Share Posted May 13, 2013 Hmm I don't have much experience with the forward/reverse set of gears as most of the time I'm chucking them out and putting a forward-only kit into the transmission. I do however have a link to the wonderful forum that is MonsterGT.com. They have a section on the forward/reverse here, but typically that section doesn't really tell you much : http://monstergt.com/articles/transmission_shifting_reverse.php Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 13, 2013 Author Share Posted May 13, 2013 That's a start mate. Many thanks. Quote Link to comment Share on other sites More sharing options...
the-badger Posted May 14, 2013 Share Posted May 14, 2013 if i remmember right the thundertiger box is simmilar to the t maxx gearbox and the selectors are a pain in the maxxes as well. check if the selector fork is in the right grooves on the gear and chech the selector itself for play or dammage, on the t maxx they have snap in pegs that act as the wear point on the selector and theese have a habit of falling off. http://www.todoomodelisme.com/fiches/pdf/ heres a link to a page containing the exploded view of a mta4 box hope this helps http://traxxas.com/products/models/nitro/49104tmaxxclassic-downloads this is a link to the t maxx gearbox it might help as they use the same selector fork design Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 21, 2013 Author Share Posted May 21, 2013 Awsome....cheers Badge. Will have a crack at this on the weekend. Watch this space (or the FS thread for a S28 roller). Quote Link to comment Share on other sites More sharing options...
MrPug Posted May 21, 2013 Share Posted May 21, 2013 I'll take a look in my parts box, but I think I've still got the whole reverse shaft with all the gears on it from when I FOC'd my electric MTA4. Let me know what you find in your transmission and I could sort you out with some spares maybe. Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 21, 2013 Author Share Posted May 21, 2013 Any chance you could take a pic of it if its still intact? Quote Link to comment Share on other sites More sharing options...
MrPug Posted May 22, 2013 Share Posted May 22, 2013 I already took a picture of it when I removed it from the box.. its the one in this pic with the red ring around it... I'm not sure if it is still in one piece though in my garage somewhere Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 22, 2013 Author Share Posted May 22, 2013 Great work. Thanks for that. Will have a crack at it the weekend as the weather is meant to be crap. Quote Link to comment Share on other sites More sharing options...
MrPug Posted May 23, 2013 Share Posted May 23, 2013 Just a note that the picture is of the S50 box. I'm pretty sure the S28 reverse gear setup is identical, but you will find you have a few less pieces in your box, like no metal brace, a bearing or two etc etc. Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 24, 2013 Author Share Posted May 24, 2013 Did notice you had a few extra pieces and assumed it was the difference between S28 and S50. If all else fails, may have to source a S50 box Quote Link to comment Share on other sites More sharing options...
jari Posted May 24, 2013 Share Posted May 24, 2013 if you want an S28 gearbox I might have one spare - a new one out of a RTR S28. Brushless conversion is on the cards and I already have the S50 box to replace the s28 one. Quote Link to comment Share on other sites More sharing options...
ollietheox Posted May 26, 2013 Author Share Posted May 26, 2013 Depends on how much we are talking about? Quote Link to comment Share on other sites More sharing options...
