Now be gental its the first review of a product that i have done
Right, i received this kill switch this morning after some PM's with the maker
of the Switch Blade.
First off it looks great, alot of work has gone into making this.
The kill switch its self is enclosed in a heat shrink.
On the other end of the kill switch is 3 sets of wires.
1 to the RX
2 to the LED
3 to the coil pack
So i stripped my old kill switch out and took the fan cover off to get at the coil.
Started from the radio box and worked my way backwards.
It all fits nicely inside the radio box
Then from the radio box, under the fuel tank and up towards the coil pack.
Next was to clip the female connectors to the wire, you do get some clips but i decided to
use my old one and solder them on, as i dont run a kill button.
Once soldered, i clipped onto the coil and replaced all the fan cover back and then tested the
kill switch.
I tested it with the 3rd channel, TX off and then RX off. It killed the engine everytime.
I have not tested the out of range yet, because i dont get out of range issues (touch wood)
Also i have not tested the battery yet, as my RX battery was full charged and so was my TX
ones.
Here is a video of the test.
IMO i think this kill switch is well worth the £35
Comes with instructions which are easy to follow and all the parts attached.
Thanks for reading this review, any comments welcome. Just remember this was my first review lol
Gav
Edited by Sphinx, 20 January 2012 - 04:09 PM.
