koy Posted April 30, 2005 Share Posted April 30, 2005 Ok i rev ok, when i leave it ideling it does it for 20 seconds (no problems) then it cuts out. BTW it is brand new. Quote Link to comment Share on other sites More sharing options...
Colt Posted April 30, 2005 Share Posted April 30, 2005 There should be a wee dile at the side of the accelator push that up a notch or to Quote Link to comment Share on other sites More sharing options...
doom56 Posted April 30, 2005 Share Posted April 30, 2005 mmm is it still in the run-in stage if so this is normal but if you have done more then 8 tanks then try richin it up a bit see if that helps cos mine does that but does not bother me tho Quote Link to comment Share on other sites More sharing options...
koy Posted April 30, 2005 Author Share Posted April 30, 2005 it doesn't really bother me, since i can use that other than holding the fuel tube to kill it. Its justm that its new and worryed me. lol Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted April 30, 2005 Share Posted April 30, 2005 mmm is it still in the run-in stage if so this is normal but if you have done more then 8 tanks then try richin it up a bit see if that helps cos mine does that but does not bother me tho ← i've had that prob in the past, ya right doom who leaves it idling longer than 20 sec anyway lol burn baby Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted May 6, 2005 Share Posted May 6, 2005 erm it could be loading up with fuel cuasing the glow plug to cool down, this would then couse the engine to stall. Quote Link to comment Share on other sites More sharing options...
tango10 Posted May 6, 2005 Share Posted May 6, 2005 is it a trx engine? Quote Link to comment Share on other sites More sharing options...
Samari Posted May 6, 2005 Share Posted May 6, 2005 20 seconds is normal, this is nothing to worry about. Is the car running O.K at other speeds? Quote Link to comment Share on other sites More sharing options...
koy Posted May 7, 2005 Author Share Posted May 7, 2005 yeah its allright at other speeds, im still in the run in(bad weather ) Quote Link to comment Share on other sites More sharing options...
