.AJ. Posted December 10, 2020 Share Posted December 10, 2020 The esc mount is in the same place in relation to the centre diff on the Kraton and Mojave, you trim the lip off the mount and it fits fine 👍 2 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 10, 2020 Share Posted December 10, 2020 43 minutes ago, mydoddy69 said: Your soon find out for sure I’ll be opening mine up to check before running it mind as you never know with Arrma 😂👍 Mine just arrived, will also take the rear diff out once i got time. 41 minutes ago, mydoddy69 said: I just bought a max6 so care to share the technique for fitting it, if there is one lol Not much to it. If you look at the ESC tray, there's a lip towards the motor mount. You have to cut/dremel/grind/sand that away. This one. I think it does fit even without grinding it down, if i recall correctly it's usually the motor wires being too short for it to mount right there. You just got to drop the motor in, slap the ESC in that place (it'll fit without modification if i'm not mistaken), and see if the motor wires are long enough to reach the ESC. If not, that lip has to go. Double sided tape, done. Or, if you wanna be fancy, there's a adapterplate on thingieverse, you could have @Paul Busby 3d print that. It's a plate that adapts the mounting pattern to a Max6 mounting pattern. Looks like this one. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 10, 2020 Share Posted December 10, 2020 If you are using the HW 4985 the motor wires are just a tiny bit short if you don’t trim the lip off, plus with the lip off you can get more contact area for double sided tape. I used Vhb tape, the screws with rip out of the mount before the esc becomes unstuck 😂 1 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 10, 2020 Share Posted December 10, 2020 In regards to the rear diff: Saves me the hassle of getting shims if necessary. Nice touch. 1 Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted December 10, 2020 Share Posted December 10, 2020 I just bought a max6 so care to share the technique for fitting it, if there is one lol These guys have all covered it pretty well so far. You can also fit at 90° to the stock position, with the motor power sockets next to the side tray, but obviously you then may need extensions.If you do want an adapter plate, just let me know. Could print one off today.I have been working on an extended ESC tray to fit it with less faffing about trimming the lip but so far haven't got the measurements quite right... It's a surprisingly hard part to get right. 2 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 10, 2020 Share Posted December 10, 2020 Gonna be interesting to route that servo cable.. Pops out uncomfortably close to the front driveshaft. Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted December 10, 2020 Share Posted December 10, 2020 (edited) 13 minutes ago, m4inbrain said: Gonna be interesting to route that servo cable.. Pops out uncomfortably close to the front driveshaft. Yeah, I have the Titanium driveshafts which are thicc boys, so it's even more uncomfortable! I havent seen anyone mention it as a problem, mind. I solved it using a nylon cable clip but its impossible to take a photo of without dismantling the truck. I'm trying to find a link for what I used, it's sorta like a cable tie base, but just a clip that you slide the cables into. Suppose I could print something to attach to the bottom of the servo mount to guide it 😁 Edit: https://www.ebay.co.uk/itm/172334991768?var=471155312552&mkevt=1&mkcid=28&chn=ps Edited December 10, 2020 by Paul Busby Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 10, 2020 Share Posted December 10, 2020 I'll get creative bud, cheers. Having the servo bolted in properly now, it's actually okay, though not much wiggle room. Now to figure out if that MMX came with double sided tape, can't find it? Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted December 10, 2020 Share Posted December 10, 2020 1 minute ago, m4inbrain said: I'll get creative bud, cheers. Having the servo bolted in properly now, it's actually okay, though not much wiggle room. Now to figure out if that MMX came with double sided tape, can't find it? If not, the Gorilla mounting tape is excellent for these purposes. Clean with rubbing alcohol, lightly heat the surfaces, stick it down hard... will never come off unless you want it too Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 10, 2020 Share Posted December 10, 2020 Add to the worlds shortest power leads, the world shortest sensor wire. -.- 1 Quote Link to comment Share on other sites More sharing options...
Skynet5 Posted December 12, 2020 Share Posted December 12, 2020 On 10/12/2020 at 08:51, m4inbrain said: In regards to the rear diff: Saves me the hassle of getting shims if necessary. Nice touch. Was that included in the kit bought from modelsport? What electrics did you go for? Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 12, 2020 Share Posted December 12, 2020 7 minutes ago, Skynet5 said: Was that included in the kit bought from modelsport? What electrics did you go for? I bought from wheelspin, but i assume that's in all of them. In regards to electrics: Something different. Quote Link to comment Share on other sites More sharing options...
Skynet5 Posted December 12, 2020 Share Posted December 12, 2020 16 minutes ago, m4inbrain said: I bought from wheelspin, but i assume that's in all of them. In regards to electrics: Something different. Just read your thread. Interesting , mt410 is my other thought. I already have an eb48 2.0 so keeping in the same brand is tempting, just because support and supplies from rprc is so good. Decisions decisions. Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted December 12, 2020 Share Posted December 12, 2020 Depends on what you want to do. The EXB can hold more power, and the purpose for this build was just that. The MT410 certainly is a good choice too, just wasn't the right one for me at this point. Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted December 12, 2020 Share Posted December 12, 2020 27 minutes ago, m4inbrain said: Depends on what you want to do. The EXB can hold more power, and the purpose for this build was just that. The MT410 certainly is a good choice too, just wasn't the right one for me at this point. There is a dude on the Tekno bashing Facebook groups with an MMX8S in his righ, lots of very custom work done to it, and he managed to get 8hp through the drive train 😂 Ordinarily though, its a 4S truck, 6S if you buy some of the optional extras such as steel spur and diff cases. Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted December 13, 2020 Share Posted December 13, 2020 10 hours ago, Skynet5 said: Just read your thread. Interesting , mt410 is my other thought. I already have an eb48 2.0 so keeping in the same brand is tempting, just because support and supplies from rprc is so good. Decisions decisions. This Arrma certainly isn’t of Tekno quality comparing my Mt410 to My EXB Tekno certainly have the edge on parts quality but then again the Tekno is more money so you’d expect that to be the case 👍 This exb will need 6s for sure the Mt410 only needs 4s so that’s also something to factor 👍 same as the mt410 will need wheels tyres a body shell and paint where as this doesn’t. 👍 Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted December 13, 2020 Share Posted December 13, 2020 As someone who owns both an MT410 and a "Full Option" Kraton, I can honestly say that I can't pick between them in terms of a favourite. The MT410 drives like what it is, an elite level race buggy, with big truggy arms, and big wheels... on steroids... it's bonkers. I just like to the way it drives, it's super smooth and precise. You have loads of control in any circumstance, even in the air with the smaller MT wheels. You still want to jump it, but everything feels a bit more elegantly poised with the Tekno. The Kraton on the other hand is more of a pure bred hooligan, It's not really refined at all. Sure, it has design and adjustment that's hung on from it's Team Durango roots but its mostly been stripped out for more cost efficient production (biggest annoyances are the servo saver and the steering posts IMO, I use Durango ones). It's a very raw truck, and when you drive it is just cries out to be jumped as high as you can possibly get it to jump, go as fast as you can possibly get it to go, and do skids and far as you can make it skid. But I have owned my Kraton over a year now, and have been CONSTANTLY tweaking it to get it the way I like it, it took ages, lots of daft little problems halting my bash sessions, and a lot of mods. The Tekno on the other hand, was wonderful from the minute I put a battery in there. Costwise at this stage, given the Kraton breaks and the Tekno just... doesn't... probably not dissimilar after 1 year of ownership. The EXB does change things, as it has a lot of the options I bought as extra equipped from the get go. Quote Link to comment Share on other sites More sharing options...
Skynet5 Posted December 18, 2020 Share Posted December 18, 2020 Pretty confused with this exb. Sounds like the diffs are poor. Shims needed out side the diff? Shims needed inside the diff? Is the rear diff a standard gear diff? Is the rear diff have LSD ? Quote Link to comment Share on other sites More sharing options...
Skynet5 Posted December 19, 2020 Share Posted December 19, 2020 Max8 with 2200 and 6s a good combo? modelsport think so... Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted December 19, 2020 Share Posted December 19, 2020 4 minutes ago, Skynet5 said: Max8 with 2200 and 6s a good combo? modelsport think so... It's ok. The Kraton is a bit of a chunk though. The Max8 and 2200kv will definitely do the job, but you will likely end up with a tiny pinion and some hot electrics. I'd go Max 6 and a motor with a KV somewhere between 1600-2000. That gives you a few more gearing options. Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted December 19, 2020 Share Posted December 19, 2020 6 hours ago, Skynet5 said: Max8 with 2200 and 6s a good combo? modelsport think so... Owning a recent version I can confirm the diffs are sorted the shims are including in case you wish to add more due to manufacturing tolerance in the plastics. It’s just a safety net in case is all Motor wise yeah the 2200 combo is fine these are geared low so you’ll have a few gearing options, unless your going to go with a bigger motor can down the road the 150a max8 is fine it’s practically what the use from the factory in the rtr rigs 👍 Dont get suckered into the must have rubbish use it enjoy it and upgrade it as and when or if needed 👍👍 1 Quote Link to comment Share on other sites More sharing options...
Tony Posted December 19, 2020 Share Posted December 19, 2020 (edited) @m4inbrain "that's the reason why i didn't buy a release EXB - but the second batch (12-16th of december) is fixed." Is there a way to know if I have the 2nd batch when I receive the box today from Modelsport? Thanks Edited December 19, 2020 by Tony Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 19, 2020 Share Posted December 19, 2020 All new ones are second batch, all the og ones were sold months ago Quote Link to comment Share on other sites More sharing options...
Tony Posted December 19, 2020 Share Posted December 19, 2020 1 hour ago, .AJ. said: All new ones are second batch, all the og ones were sold months ago Phew, thank you. 👍 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 19, 2020 Share Posted December 19, 2020 The diffs appear to be sorted this time round 👍 Quote Link to comment Share on other sites More sharing options...
