Devin Posted July 29, 2015 Posted July 29, 2015 Ahh okay let me know how those gens ace packs do ya I may pick up some and I'm not to fussed about the radius just it turn tighter one way than the other and I can't see why that's the case unless I lengthen the steering links but then wheels will be out so abit of catch 22 Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 You might need to shorten the link between the servo horn and at.m mine came way to long I also went in and adjusted my endpoint so on the servo:) Quote
Devin Posted July 29, 2015 Posted July 29, 2015 Yeah I thought I looked at it and was like what servo is gunna reach that then so I shorted it do you think a 18t pinion and 4s would be good until I get a 6s set up Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 I'd go 20 on 4s that should liven it up temps are super cool on mine so it wasn't a problem Quote
Devin Posted July 29, 2015 Posted July 29, 2015 Ahh okay cool can you take a picture of how you layed out your servo please Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 (edited) Couple of quick pics off my iPad Edited July 29, 2015 by mydoddy69 1 Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 Can't really see mine with the brace on sorry Mine is on the left hand side as you look from the underside not the middle mount if that helps any ? Quote
Devin Posted July 29, 2015 Posted July 29, 2015 That looks sexy I'll have to get one now, no problem I'll get a pic of mine Sent from my A0001 using Tapatalk Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 Just checked mine and it looks the same Quote
Devin Posted July 29, 2015 Posted July 29, 2015 Must be the steering links then I've noticed when the steering is on lock the caster block and steering knuckle arnt touching and it's the bell rank hitting the diff case however if I lengthen the links the wheels will be out of line Sent from my A0001 using Tapatalk 1 Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 Right I have checked mine and it's the same as yours one side seems to turn further than the other on full rates .. So your need to adjust your end points for each side not just the throw .. If it's binding then that's something differentt and your need to locate the source and free it up Hope that helps Quote
Devin Posted July 29, 2015 Posted July 29, 2015 Just looked when the suspension is under compression the steering knuckles and castor blocks touch and I check the crank and when there is suspension compression the crank moves in more Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 I'll have to check mine but can't say I have noticed this happening ? Quote
Basher 46 Posted July 29, 2015 Posted July 29, 2015 Couple of quick pics of my iPad Nice ipad [emoji2] Sent from my HTC One_M8 using Tapatalk Quote
Basher 46 Posted July 29, 2015 Posted July 29, 2015 Haha, seriously though thats a nice truck bud , I was recently chuffed with a H2 I received,build quality was spot on [emoji2] Sent from my HTC One_M8 using Tapatalk Quote
Devin Posted July 29, 2015 Posted July 29, 2015 So now I've spent some time sorting the alignment issues the truck seems all good just needs a bigger pinion Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 29, 2015 Author Posted July 29, 2015 Hooray !! I knew you would get there Quote
Devin Posted July 29, 2015 Posted July 29, 2015 Haha the thing just flips but it's a cool experiencing driving something like that Sent from my A0001 using Tapatalk Quote
capri-boy Posted July 30, 2015 Posted July 30, 2015 Devin, if your struggling I've got a some big mod 1's i don't use at the moment. Going rate seems to be a fiver posted, though will combine if you want a couple - def got a few 19's and a 20, maybe a 21 and vague memory of some monster thing like a 23. Doddy - love the shell - have you had to mod the body mounts? Semi gutted I missed out on the used one, will bite on a new roller if either it drops a little or i fall on a new combo - fed up of robbing combo's from peter for paul and already a buggy system short. 1 Quote
mydoddy69 Posted July 30, 2015 Author Posted July 30, 2015 Doddy - love the shell - have you had to mod the body mounts? Semi gutted I missed out on the used one, will bite on a new roller if either it drops a little or i fall on a new combo - fed up of robbing combo's from peter for paul and already a buggy system short. No fella not to the body's mounts but I have tweaked the bumpers Both front and rear bumpers have a slight curve so I used my heat gun to warm them up and straighten them up a bit Ideally it needs to sit a few mm lower but that creates to many headaches on the esc mounting and catching the front shocks on lower compression.. I have added some foam padding to the roll cage to fill the gap which I hope will add some extra support for the shell .. The shell itself is a Proline Ford F 100 1966 so a nice old school style !.. Paint well that's not quite decided on yet 1 Quote
Devin Posted July 31, 2015 Posted July 31, 2015 So I've ran my truck a few times now and nothing has gone wrong yet, I still have to brace my chassis though so I'm taking it easy till I get that done and I really do need to gear up it runs out of puff so quick so I think a 19t pinion is on the cards Sent from my A0001 using Tapatalk Quote
mydoddy69 Posted July 31, 2015 Author Posted July 31, 2015 If you just running 4s id go 20t /21t Quote
Devin Posted July 31, 2015 Posted July 31, 2015 I would but it lasts like 40 minutes on a charge and it gets quite warm after a full run Sent from my A0001 using Tapatalk Quote
