chassis flex
  • Please log in to reply
1 reply to this topic
#1 ratman
ratman
    MSUK Regular
  • Members
  • PipPipPipPipPipPipPipPip
  • 1,016 posts
  • Gender:Male
  • RC Cars:Tamiya TRF417, Traxxas Stampede, M03 mini,
Posted 16 October 2011 - 08:35 AM
im looking at buying a thinner chassis plate for my mi4.i currently have the standard 2.5mm chassis but have been looking at getting the 2.0mm soft weave mi4cx version to hopefully give me more front end grip. i race on astro carpet with yello minipins. recon it will work?
also anyone know where there is a guide to tuning chassis flex?
#2 Garry
Garry
    Racers do it 5mins at a time!
  • Forum Staff
  • 22,523 posts
  • Gender:Male
Posted 17 October 2011 - 03:32 PM
It should improve grip all over, not just the front, so basically it'll gain turn-in and stability. General rule of thumb is, the stiffer one end of the car is, the less traction that end of the car will generate.
The Xray setup book doesn't go into that much detail about flex:
''Chassis flex (rigidity) is not a readily-available tuning option in typical RC cars. Up until now the nature of chassis technology resulted in a fixed
amount of flex being built into each chassis plate and top deck. Therefore racers have always used chassis flex as an unchanging foundation from
which they have used all other tuning options to dial in a working setup. Each major change in track and/or tire grip conditions required an entire
re-build of their car with either a thicker or thinner chassis. This limitation reduced the ability for drivers to effectively adapt their car’s fundamental
setup from week-to-week, or race-to-race. Same day changes that were needed due to significant temperature or weather changes were simply out
of the question.
With necessity being the mother of invention, the advent of top decks differing in width, mounting points and thickness have become the standard
for tuning chassis flex. However, the flex characteristics they provide alone are still inadequate when extreme changes are needed.
With XRAY Multi-Flex Technology™ (MFT), drivers can now not only change the amount of overall flex to the extreme, but they are also able to finetune
the differing characteristics of both torsional (twisting) and lateral (front to rear) flex. MFT works by simply using, or not using, the rigidity of the
aluminum bulkheads between the chassis plate and top deck. For larger changes in flex, screws connecting the bulkheads to the chassis (at strategic
locations) are either inserted or removed ; for fine tuning flex, screws mounting the top deck to the bulkheads are either inserted or removed. This
provides the ability for the driver to change chassis flex, within minutes, from a stiff setting - resembling today’s common 3mm+ chassis plate and
wide/thick top deck (high grip foam racing) - to a flexible setting resembling today’s common 2mm chassis plate with slim/thin top deck (low grip
asphalt racing).
Utilizing this technology in conjunction with the rest of the T2 innovations from XRAY, drivers can now easily and quickly change the T2’s fundamental
setup without ever having to disassemble the chassis/deck/bulkhead and introduce unwanted chassis tweak.
Modelsport UK
