MattyGage Posted September 6, 2017 Share Posted September 6, 2017 I bought nitro rc bug crusher 1:10th for my son but seems to be having problems when trying to drive it up hill its revving fine but not moving any suggestions as what it could be new to the nitro rc scene Quote Link to comment Share on other sites More sharing options...
J.K Posted September 6, 2017 Share Posted September 6, 2017 It could be a clutch issue, does it run fine on the flat? 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted September 6, 2017 Share Posted September 6, 2017 +1 with James, worn clutch shoes Quote Link to comment Share on other sites More sharing options...
MattyGage Posted September 6, 2017 Author Share Posted September 6, 2017 He has to rev it a little more thab i thought he would have to but once it gets going its not to bad Quote Link to comment Share on other sites More sharing options...
Smoothybb Posted September 7, 2017 Share Posted September 7, 2017 That sounds like clutch shoe springs. 1 Quote Link to comment Share on other sites More sharing options...
MattyGage Posted September 7, 2017 Author Share Posted September 7, 2017 Are they easy changeable by any chance Quote Link to comment Share on other sites More sharing options...
Smoothybb Posted September 7, 2017 Share Posted September 7, 2017 Reasonably. As most things rc, there is a knack to them. I recall a number of puncture wounds to fingers but it's been a while since i messed with nitro. Sorry it's 1/10 isn't it. They're easier to change than a 1/8th as it's one spring. If its quite new then unlikely the clutch has gone already though. Does all of the drivetrain move without any binding/resistance? Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted September 7, 2017 Share Posted September 7, 2017 Good shout smoothy....If it is the springs, they'll be too stiff... with those symptoms. I'd still say the symptoms also point to worn clutch shoes. Take your clutch bell off and take a pic to post on here Matty. 4 minutes ago, Smoothybb said: Reasonably. As most things rc, there is a knack to them. I recall a number of puncture wounds to fingers but it's been a while since i messed with nitro. Ever built up a 4 shoe race clutch? frustratingly fiddly doesn't quite describe it..... Allthough it does describe Jimmy Saville rather well... 1 1 Quote Link to comment Share on other sites More sharing options...
Smoothybb Posted September 7, 2017 Share Posted September 7, 2017 44 minutes ago, Fly In My Soup said: Ever built up a 4 shoe race clutch? frustratingly fiddly doesn't quite describe it..... Allthough it does describe Jimmy Saville rather well... Ooooh, I shouldn't laugh....... Looked at a 4 shoe for a while but 3 shoes are bad enough to change! I agree it does sound like a worn shoe issue but for some reason I thought it sounded like a newish purchase. I was guessing either the spring wasn't working quite right or just needed a bit of a stretch. 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted September 7, 2017 Share Posted September 7, 2017 You could well be right dude.... Mattygage, the balls in your court, whip your engine out and unscrew the bolt holding the clutch bell on Some pics of the shoe setup would help us confirm the issue 1 Quote Link to comment Share on other sites More sharing options...
MattyGage Posted September 8, 2017 Author Share Posted September 8, 2017 Thanks for the suggestions ill have a look over the weekend and post some pictures 1 Quote Link to comment Share on other sites More sharing options...
MattyGage Posted September 28, 2017 Author Share Posted September 28, 2017 On 07/09/2017 at 21:11, Smoothybb said: Ooooh, I shouldn't laugh....... Looked at a 4 shoe for a while but 3 shoes are bad enough to change! I agree it does sound like a worn shoe issue but for some reason I thought it sounded like a newish purchase. I was guessing either the spring wasn't working quite right or just needed a bit of a stretch. It's only 10 months old only been used 4/5 times tho 1 Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted September 28, 2017 Share Posted September 28, 2017 1 hour ago, MattyGage said: It's only 10 months old only been used 4/5 times tho Hmmmm.... As smoothy pointed out, if it is that new, then it is unlikely that the issue is the clutch shoes.... One way to clear this up once and for all would be to take a video of the issue as it's happening...I.e. when it's struggling to drive up a hill Quote Link to comment Share on other sites More sharing options...
Fly In My Soup Posted September 28, 2017 Share Posted September 28, 2017 P.s. did you get it from new? If so, did you ensure that you 'broke' the engine in? If it's revving well then I'll assume you have.... But that would then point attention to the clutch being an issue.... Hmmmm...I'm stumped.... Mattgage, you'll probably still need to pull the engine off and dissembled some of the clutch to diagnose this issue... Without a video or pics its very hard for us to help with an issue like this Quote Link to comment Share on other sites More sharing options...
Shudson Posted September 28, 2017 Share Posted September 28, 2017 I have no experience of this truck, but just looked at spec. It appears to have a slipper clutch and it may well be that it needs adjustment. Quote Link to comment Share on other sites More sharing options...
MattyGage Posted January 4, 2018 Author Share Posted January 4, 2018 Thanks for the advice will look in to how to do it Quote Link to comment Share on other sites More sharing options...
MattyGage Posted January 4, 2018 Author Share Posted January 4, 2018 On 28/09/2017 at 09:27, Fly In My Soup said: Hmmmm.... As smoothy pointed out, if it is that new, then it is unlikely that the issue is the clutch shoes.... One way to clear this up once and for all would be to take a video of the issue as it's happening...I.e. when it's struggling to drive up a hill I will get a video together a d post on here to show thanks again 1 Quote Link to comment Share on other sites More sharing options...
Smoothybb Posted January 4, 2018 Share Posted January 4, 2018 I didnt see slipper clutch (lack of research) that could well be the culprit. 1 Quote Link to comment Share on other sites More sharing options...
