Lionel Posted November 22, 2020 Share Posted November 22, 2020 Ive been out of the hobby for far too long and everything is new to me.I read and watched a lot so know a bit about modern RC electric.I decided to get a Absim Sherpa as it seamed best bang for buck,but Im already looking for up grades.First thing Im looking at to change is the motor.what would be a good sensored motor combo? I want low down torque and like the idea of the car maintaining the same slow speed without me increasing the throttle. Next,it looks similar to the trx4 and scx10 so do any of the parts fit from these,I thinking bumpers, wheel weights,portal housings etc. Quote Link to comment Share on other sites More sharing options...
oodboo Posted November 22, 2020 Share Posted November 22, 2020 I put the hobbywing quicrun fusion in my scx10ii. I think that does what you're describing, there's a video on my build thread here: https://www.msuk-forum.co.uk/forums/topic/243394-oodboos-scx10ii-a-team-van/?do=findComment&comment=2527028 1 Quote Link to comment Share on other sites More sharing options...
Lionel Posted November 22, 2020 Author Share Posted November 22, 2020 thats what Im after,thanks. Quote Link to comment Share on other sites More sharing options...
oodboo Posted November 22, 2020 Share Posted November 22, 2020 Can't help much with parts compatibility, this scx10ii is my first crawler. 1 Quote Link to comment Share on other sites More sharing options...
Redback Posted November 22, 2020 Share Posted November 22, 2020 I would hold out for the R2 Axe system maybe as they have wider selection of motor kv, bigger cans and logging etc. The v1 axe system was solid but i feel the motors dont contain enough motor, Alternatively Castle have very smooth startup and can be further tweaked via power curve that the axe v1 / 1.1 system doesn't have. And they work with most sensored or sensorless motors that the Axe systems wont do. The sherpa will not be parts compatible with the trx4, maybe a bumpers will fit with some cutting, but the portals for example are not even close to being similar so all the weights wouldnt fit imo. You might be better off looking at heavyweight rims rather than portal weights at the moment, should give the same effect and be compatible with any truck you want to be heavy :D. I would highly recommend these. https://www.modelsport.co.uk/index.php?product_id=432791 Quote Link to comment Share on other sites More sharing options...
oodboo Posted November 22, 2020 Share Posted November 22, 2020 29 minutes ago, Redback said: I would highly recommend these. https://www.modelsport.co.uk/index.php?product_id=432791 They're the wheels I use, but I sprayed mine red. They're heavier than I was expecting them to be as they're aluminium rather than steel. Very good value as well. Quote Link to comment Share on other sites More sharing options...
Lionel Posted November 23, 2020 Author Share Posted November 23, 2020 20 hours ago, Redback said: I would hold out for the R2 Axe system maybe as they have wider selection of motor kv, bigger cans and logging etc. The v1 axe system was solid but i feel the motors dont contain enough motor, Alternatively Castle have very smooth startup and can be further tweaked via power curve that the axe v1 / 1.1 system doesn't have. And they work with most sensored or sensorless motors that the Axe systems wont do. The sherpa will not be parts compatible with the trx4, maybe a bumpers will fit with some cutting, but the portals for example are not even close to being similar so all the weights wouldnt fit imo. You might be better off looking at heavyweight rims rather than portal weights at the moment, should give the same effect and be compatible with any truck you want to be heavy :D. I would highly recommend these. https://www.modelsport.co.uk/index.php?product_id=432791 very useful,thanks Quote Link to comment Share on other sites More sharing options...
