vandalbulldog Posted June 8, 2014 Share Posted June 8, 2014 So, the Ridgecrest has developed a dry grating noise in the centre diff area. The car moves fine so thinking that the diff must have a problem. If I'm going to be stripping it down, are there any recommends to improve the drivetrain whilst its in bits?? Sent from my iPad using Tapatalk HD Quote Link to comment Share on other sites More sharing options...
tonysmini Posted June 8, 2014 Share Posted June 8, 2014 Check the three screws that hold the gearbox outdrives, I had one work loose on my Wraith and make the same noise. Strip, clean and a little loctite and it's not bothered me since. Quote Link to comment Share on other sites More sharing options...
Gaz! Posted June 8, 2014 Share Posted June 8, 2014 yep same happened on my crest too, threadlock did the job though perfectly. depending on mud and wet running etc. while you have the gearbox out, maybe worth re-newing the bearings?? 1 Quote Link to comment Share on other sites More sharing options...
vandalbulldog Posted June 8, 2014 Author Share Posted June 8, 2014 yep same happened on my crest too, threadlock did the job though perfectly. depending on mud and wet running etc. while you have the gearbox out, maybe worth re-newing the bearings?? Top man, cheers as always Gaz. Hopefully nothing major to sort as the Ridgecrest is my 6yr olds and he is gutted it is noisy!! VB. Quote Link to comment Share on other sites More sharing options...
vandalbulldog Posted June 12, 2014 Author Share Posted June 12, 2014 10 / 10 as usual Gaz. When i stripped the box i found a seized bearing which was also fused onto the shaft running through it. No wonder there was so much noise! New bearings on order and hopefully will have it back out by weekend! VB. Quote Link to comment Share on other sites More sharing options...
