don shaleone Posted January 3, 2012 Share Posted January 3, 2012 Just picked up a buggy off ebay it was quite cheap so I dont mind to much if it needs a new engine, but the seller seemed very sure it would work just hadn't been used in a very long time. Firstly I had to buy a steering servo arm and a charger for the glow heater, now I've got these sorted I've been trying to start it with no sucess. I've blown the fuel round to the carb and tried to start it with heating glow plug etc but it dont sound like it wants to do anything. If anyone has any tips or ideas as to why it wont start I would be grateful It is a GV Model Panther Force .12 I believe. Thanks! Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 take the glow plug out and plug it into the glow heater to see if it heats up Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 Ive already tried this mate thanks for the reply Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 have you tried resetting the needles back to factory? Quote Link to comment Share on other sites More sharing options...
anton Posted January 3, 2012 Share Posted January 3, 2012 Heat the engine up with a hair dryer or heat gun (or better still, an engine pre-heater i.e. surestart or home made equivalent) - it makes starting engines much easier and reliable. Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 Nope, how do I find out what were set at from factory? The idle screw was screwed all the way in when I first got it :S Heat the engine up with a hair dryer or heat gun (or better still, an engine pre-heater i.e. surestart or home made equivalent) - it makes starting engines much easier and reliable. Yeah I need to try this. Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted January 3, 2012 Share Posted January 3, 2012 (edited) hi mate,, i would replace the fuel lines as they maybe gummed up,, clean the airfilter in some nitro fuel and dry it as it may also be gummed up and dirty,, put a new glow plug in as even if they still light up it can be knackered, and as stated before find the factory settings for the carb and reset it back to factory standard,, search google for the settings mate Edited January 3, 2012 by scotty1986 Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 hsn 2.5 turns from closed lsn flush idle gap about 1mm Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 The fuel lines seem fine I had to blow through the tube to get the fuel to the carb though, when I tried the covering the exhaust method nothing happened, could that mean something is wrong? Also their is a spring type button on the fuel tank it doesnt seem to do anything, what is it for? The air filter is dirty but just for trying to get started couldnt I just remove the air filter so it gets nice clean air unrestricted? I bought a brand new glow plug today. Any ideas where I could find the factory needle settings? Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 hsn 2.5 turns from closed lsn flush idle gap about 1mm Thanks for that info, a bit technical for me lol is that hsn high speed needle, lsn low speed needle? not sure about idle gap? sorry lol Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted January 3, 2012 Share Posted January 3, 2012 hatzy has just posted them for you mate,, and you could take the filter off but then theres a chance something could get in the carb and that wont end well,, and the button your on about will be a primer to get fuel to the engine but there not very reliable as you have found out and can cause air leaks in the tank Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 yyes you are right about hsn,lsn. with the air filter off, look down the hole, the gap in the throttle body should be about 1mm. the spring button is for priming(pushing fuel to the carb) if adjusting the needles doesnt do anything, try droppin a little (not alot) nitro down the carb. also is the fuel fresh? Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted January 3, 2012 Share Posted January 3, 2012 idle gap is how much your carb stays open at idle so it ticks over mate take your air filter off and close your carb fully and adjust the screw till your carb has a gap of 1mm Quote Link to comment Share on other sites More sharing options...
Jumper Posted January 3, 2012 Share Posted January 3, 2012 ^ he beat you to it again Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 check the idle gap with the radio on and trim (little knob on the controller says th trim) set to the middle/0 Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted January 3, 2012 Share Posted January 3, 2012 ^ he beat you to it again ???? maybe he did but my post is still more relevant than yours Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 now now ladies Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 Yep fuel is brand new today, so if the needle thing dont work, do I put the fuel through the hole of the air filer Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 take the air filter completly off for now. drop the fuel directly into the carb Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted January 3, 2012 Share Posted January 3, 2012 now now ladies Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 the idle gap is about 2mm, where is the high and low needles located? do they adjust the idle gap? Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 (edited) where the fuel line attaches is the hsn, lsn on this carb according to the manual is just under that on the side of the carb body. the idle set screw is a little black screw with a spring on it Edited January 3, 2012 by HATZY Quote Link to comment Share on other sites More sharing options...
HATZY Posted January 3, 2012 Share Posted January 3, 2012 http://www.ofna.com/pdf/eng-force12s,15s.pdf Quote Link to comment Share on other sites More sharing options...
don shaleone Posted January 3, 2012 Author Share Posted January 3, 2012 Ahhh right found them all now, will have a go at starting it Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted January 3, 2012 Share Posted January 3, 2012 good luck mate Quote Link to comment Share on other sites More sharing options...
