Jacksprogis Posted September 9, 2012 Share Posted September 9, 2012 It seems many others and I have had problems with diff cases on maverick scout's where they 'slip' after a tough course or after a while of running . They cost 1 Quote Link to comment Share on other sites More sharing options...
Gaz! Posted September 9, 2012 Share Posted September 9, 2012 glad you got it to work mate, told you axial bits fitted with a little work Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted September 9, 2012 Author Share Posted September 9, 2012 glad you got it to work mate, told you axial bits fitted with a little work Yeah mate , Better than a new case The dremel has been busy Quote Link to comment Share on other sites More sharing options...
Gaz! Posted September 9, 2012 Share Posted September 9, 2012 should be one less thing to worry about now then mate Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted September 9, 2012 Author Share Posted September 9, 2012 should be one less thing to worry about now then mate Yep mate Never been so happy over making something work . Will be doing the rear when it break's . Quote Link to comment Share on other sites More sharing options...
Matty221133 Posted September 9, 2012 Share Posted September 9, 2012 good man finally a fix lol in mine a made a small coller to go over the part inside the case then had to use a hydrolic press to push it over it has lasted about 4 months now but i have started to get a little bit of slop again so will be doing this mod asap Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted September 10, 2012 Author Share Posted September 10, 2012 good man finally a fix lol in mine a made a small coller to go over the part inside the case then had to use a hydrolic press to push it over it has lasted about 4 months now but i have started to get a little bit of slop again so will be doing this mod asap Sounds good , feel free to message me over it dude Let me know how you go on Quote Link to comment Share on other sites More sharing options...
Matty221133 Posted September 10, 2012 Share Posted September 10, 2012 Sounds good , feel free to message me over it dude Let me know how you go on will do mate will do Quote Link to comment Share on other sites More sharing options...
ScottPro8.5 Posted September 10, 2012 Share Posted September 10, 2012 Great mod jack! Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted September 10, 2012 Author Share Posted September 10, 2012 will do mate will do Good good Great mod jack! Cheers mate Quote Link to comment Share on other sites More sharing options...
goofus-nut Posted September 13, 2012 Share Posted September 13, 2012 hi does anybody know why can't you use axial shafts with the axial locker in the scout Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted September 13, 2012 Author Share Posted September 13, 2012 (edited) hi does anybody know why can't you use axial shafts with the axial locker in the scout In theory you could but i'm skint Edited September 13, 2012 by jacksprogis Quote Link to comment Share on other sites More sharing options...
tom24-7 Posted September 16, 2012 Share Posted September 16, 2012 i best open up my diffs and see how theyre holding up they may need modding too Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted September 16, 2012 Author Share Posted September 16, 2012 i best open up my diffs and see how theyre holding up they may need modding too Yeah man , they were fully greased and held up fine when she was mine Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted October 7, 2012 Author Share Posted October 7, 2012 Still holding up great 1 Quote Link to comment Share on other sites More sharing options...
sammy0100 Posted November 1, 2012 Share Posted November 1, 2012 Forgot to update this , Was holding up great until a tough line at scale nats . sNapped a dogbone right where it meets the axle . Wacked my axial ones in after a slight end trim . Thanks , Jack On a mates computer . Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted November 24, 2012 Author Share Posted November 24, 2012 Still fine Rear is nearly needing to be done Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted December 7, 2012 Author Share Posted December 7, 2012 Another 20 hours onto the scout and im now running a winch . This mod is golden . Hope this helps people , Jack Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted June 10, 2013 Author Share Posted June 10, 2013 Done a mates a few months back and someone else is running a BL scout with this done ... All still going strong Jack. Quote Link to comment Share on other sites More sharing options...
ghazghul Posted June 10, 2013 Share Posted June 10, 2013 Mine has this mod with rc4wd cvds in the front, slotted straight in. Running 13.5t sensored brushless on 2s and they are solid... in fact a dogbone in the rear snapped last time I bound up the one wheel. 3s LIPO arriving soon so will see how diffs cope! 1 Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted July 7, 2013 Author Share Posted July 7, 2013 Yet another few done that I'm aware of .... All are doing amazingly My scout shed is also holding up Despite our best efforts to break it Jack. Quote Link to comment Share on other sites More sharing options...
ghazghul Posted July 7, 2013 Share Posted July 7, 2013 Reversed mine hard and broke the rear axle where the toe link mounts have a strc lockout kit on the way which will slide right into the HD locker from this mod. Well worth doing just to give you easy options on CV's and axles from AX10s. Found a spade drill bit (13mm I think) is great to clear the diff case for the HD locker. Quote Link to comment Share on other sites More sharing options...
ghazghul Posted July 7, 2013 Share Posted July 7, 2013 Oh and test with 3s was fine, just battery too wide to fit on front. Did some big jumps on 3s including off shed roof by accident and all was fine. Got some RC4WD Twister wheels to fit which have more offset than stock so might squeeze 3s battery next to servo. Quote Link to comment Share on other sites More sharing options...
Jacksprogis Posted July 7, 2013 Author Share Posted July 7, 2013 Great dude Good to get feedback If we continued running out scout we would prolly be running VP lockers with Ud od as in the AX Jack. Quote Link to comment Share on other sites More sharing options...
ghazghul Posted July 7, 2013 Share Posted July 7, 2013 Running ax ud in the rear here, picked up the strc lockout as others hard to get. Hoping they are here soon as hoping for a Hampshire crawl at end of month. Only weak point in scout seems to be the diff. case, everything else broken is result of serious abuse/ torque. 1 Quote Link to comment Share on other sites More sharing options...
