PhilDorman Posted March 16, 2016 Share Posted March 16, 2016 Evening, I've just purchased a Hyper 9e with the sole purpose of doing speed runs. its got a HW Quicrun 150a esc and 2000kv motor. im looking for advice on spur/pinion gearing to pull as much top end speed from this combo. Any advice would be appreciated. thanks Phil Quote Link to comment Share on other sites More sharing options...
RCbutcher Posted March 17, 2016 Share Posted March 17, 2016 I think people get custom gears machined for them to get the 100mph with buggies. The guy might be in the professional sellers page. The hyper 9 is the nicest looking hyper good choice. Hopfully it's as strong as the 7 too. Quote Link to comment Share on other sites More sharing options...
capri-boy Posted March 17, 2016 Share Posted March 17, 2016 Ok, how fast do you want to go? I'm assuming you have the 4074 smooth red motor, so to get anywhere your going to need to run 6S. This will obv create issues re battery and shell which will need working round. You'll need to ditch that rear mounted centre diff for a custom spool, or lock it and fit a humongous pinion to the motor - this may not be enough though (mount will prob limit you to the low 20's). What gear ratio's does the 9e have? Will then be able to run some numbers for you. Quote Link to comment Share on other sites More sharing options...
PhilDorman Posted March 17, 2016 Author Share Posted March 17, 2016 Hi thanks for the replies, ill be using 6s, I believe the stock gearing is 15/40, 100mph is obviously the dream! Thanks Phil Quote Link to comment Share on other sites More sharing options...
