samp97 Posted April 16, 2014 Share Posted April 16, 2014 So the aftermarket Cooling head came for my trx 2.5 but now it's all installed and yes it starts but I could be driving it fine and all of a sudden it stops, why I don't know, sometimes after that it doesn't start until it has cooled down again, any ideas at all? Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 16, 2014 Author Share Posted April 16, 2014 I have also tried different glow plugs and with the hotter plug it seems to idle higher Quote Link to comment Share on other sites More sharing options...
Thunderwolf Posted April 16, 2014 Share Posted April 16, 2014 you are probably runnning it too lean ond over heating it. richen the high speed needle abit and it will stop doing it. Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 16, 2014 Author Share Posted April 16, 2014 back after more trying, i think the motor is nearly past it but it hasnt had much fuel through it, i dont know, ive tried stock carb settings, rich low end, lean low end, ive tried everything and it just wont go help bump HELP Quote Link to comment Share on other sites More sharing options...
Andythecrane Posted April 16, 2014 Share Posted April 16, 2014 Is there any compression in the engine when you try to start it?Sent from my Nexus 4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 16, 2014 Author Share Posted April 16, 2014 how do i find this out, the engine starts and runs for a while, i can get it to high rpm, second gear but after that it will it goes back to struggling to start at all Quote Link to comment Share on other sites More sharing options...
J.K Posted April 16, 2014 Share Posted April 16, 2014 Have you got the idle set correctly? Set your throttle trim to neutral (on the transmitter), pull off your air filter and adjust the idle screw until there's a 1-2mm gap at the widest point. Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 16, 2014 Author Share Posted April 16, 2014 its defiantly compression issue, new piston and sleeve for me! https://www.youtube.com/watch?v=xCdvwfi6Nfc&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 16, 2014 Author Share Posted April 16, 2014 http://www.msuk-forum.co.uk/gallery/image/28676-/ http://www.msuk-forum.co.uk/gallery/image/28678-/ http://www.msuk-forum.co.uk/gallery/image/28677-/ http://www.msuk-forum.co.uk/gallery/image/28679-/ http://www.msuk-forum.co.uk/gallery/image/28680-/ http://www.msuk-forum.co.uk/gallery/image/28681-/ 1 Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 Just a quick update, going to try and pinch the sleeve later on, just cleaned the crank and crank case Quote Link to comment Share on other sites More sharing options...
Andythecrane Posted April 17, 2014 Share Posted April 17, 2014 Its Worth a try.Sent from my Nexus 4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Anthoop Posted April 17, 2014 Share Posted April 17, 2014 Hope the pinching process you use will keep the sleeve round. Can I ask what fuel you use...and is that the only fuel this engine has been ran on? Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 It was ran in with 16 percent opti fuel and was ran on optifuel 25 Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 Is there a method that will be able to pinch better I'm not sure if this will work when it's started up, we shall see Quote Link to comment Share on other sites More sharing options...
Anthoop Posted April 17, 2014 Share Posted April 17, 2014 I will keep checking..please update on how the pinching with jubilee clip goes..and how it runs.. I will most definitely recommend you to run a fuel that contains some castor oil next time...it will give some protection when lean/hot...Byron fuel is a very good option. There are many methods to pinch a sleeve...you can buy costly equipment...you can use costly equipment that was meant for another purpose...you can send your sleeve to someone with the costly equipment (note bulk buy is cheaper).... Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 I've pinched it once and it seems tighter so I'll put it back in the car and start it up and let it idle up to temperature and see how it goes, if not I'll be saving for a new engine direct drop in break it in properly and then off we go if this doesn't work or course I'll shoot a video or two to see how it goes thanks guys! Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 So, I've pinched it once with the result of the same running you have to throttle it as soon as it's up to op temp to keep it going will try again but a little tighter, if no luck after that it's a new engine! Quote Link to comment Share on other sites More sharing options...
RCbutcher Posted April 17, 2014 Share Posted April 17, 2014 Ide start saving mate i went through this with my very first revo engine i was sure i could sort it out but i just had acouple weeks starting my engine hitting 2nd gear watching it crawl back to me and quitting half way. Waiting for it to cool and trying again with more tuning. In the end my con rod snapped and cracked the piston sleeves skirt. It was a horrible cup weeks walking everything to the feild just to walk home again with 3/4 of a tank lol. Save time and find a replacement mate plus you can uppp the power now anyway trx3.3 or picco 26 are easy to fit but the picco needs a new mount thats Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 New update pinching has worked, so much the sleeve is too tight to even get the piston in, now what! Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 tried everything to get the perfect match and it just wont have it, so, a new engine it is, its my birthday easter sunday so money from family etc, i got paid today so going to save that until i have 1 Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 17, 2014 Author Share Posted April 17, 2014 Just another update for those who are bothered just placed an order for some accessories and should be ordering a new engine on Tuesday, hopefully! if not it will be the Friday (25th). Engine will be the Picco P2 .26 Engine with the EZ Start 2 backplate and stuff, i have ordered a blue aluminium fuel filter, a schumacher 1:8 air filter, Optifuel 25% Nitro RTR Fuel and some fuel tubing to go along with it, the Revo will get a big clean between now and then and hopefully she will run! 1 Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 20, 2014 Author Share Posted April 20, 2014 One more day guys and a new engine will be on its way! Quote Link to comment Share on other sites More sharing options...
ade909 Posted April 21, 2014 Share Posted April 21, 2014 Hope the Picco works out for you matey, them Picco engines have a very tight pinch, pre heat is a must if you can. Quote Link to comment Share on other sites More sharing options...
samp97 Posted April 21, 2014 Author Share Posted April 21, 2014 will a hair dryer do as i have no heatgun anymore Quote Link to comment Share on other sites More sharing options...
ade909 Posted April 21, 2014 Share Posted April 21, 2014 Yeah a hair dryer will be better than nothing Quote Link to comment Share on other sites More sharing options...
