Posted (edited)
Well what can i say....running in went smoothly...tuning was easier than i thought althugh im sure it can be tuned even better......ran five tanks of fuel through it today at GREEN PARK in reading berkshire which is a big industrial estate.
Loads of hills and gravel and OMG how amazing is this truck??? mashed the shell up on it as i rolled it a few times.
Cannot belive how fast these damn things are and how robust, also the roto start is excellent.
going back tommorow morning for round two :)
Not doing too bad for a complete newbie to nitro....although when the repairs are needed is where i will be tested lol.
Great trucks and well worth the money.
One question......does the three speed gearbox ratio get adjusted in exactly the same way as the two speed? ie a screw under the rubber cap?
I havent adjusted it yet but i might give it a little tweak tommorow.
Also after a good run whats the main things to check for.....all ive done is check for lose screws, cleaned the air filter and basically blew as much crap off it as possible....
Edited by stepp
Posted
yeh the gear is changed the same way but thats 2nd-3rd shift, to adjust the 1st-2nd shift you need to open the box. Anyway the 3 speed is factory set for the 25 engine so you should'nt need to change it really
