Savage project!
salman
Hi,
My Savage project will start in a Few weeks.
I am planning on Selling my LST to funds this.
The Plan is to get a Savage and Make it as Light as Possible, And plonking the Collari .32 i have on order in it :D
These are some of the Hop ups i shall Have:
Carbon Fibre LCG EXT TVP'S
Custom made Carbon Fibre 3/4 MM Engine plate.
Custom made 3/4 MM Bulkhead Lower plate. X2
Custom made Carbon Fibre 3/4 MM Upper Arm brace.
Custom made 3/4 MM Rasio box.
4 bevel gear Diffs (Should be fine Or i could make 8 using a Drill)
3 Speed Transmission/Single Speed.
Nova Shock Towers.
Front Buggy shocks. X4
Cam Type Servo Saver.
Hitec 5945
Carbon Dual Disc Brakes.
Collari .32 :D
And Many more!
Should Have all this Done in a Month.
Should have a Savage with me by Next week, So i can start.
Just need to know were i can get I can get A Solid carbon Fibre sheet 3MM thick, Anyone got any ideas?
Should be more like a Truggy rather than a Truck.
Cant wait!
Thanks
Momin
Suggestion/Tips Welcome!
Get some 23MM Proline Hex if you Putting So Much Power through to the Wheels,
Help with Stenght and buy 40 Series will help alot with Grip,
If your Going for Truggy Make it Pretty Low but try Diffrent Shock Positions to see what there Like,
Make a Custom Made Radio Box not Rasio Box, No need for a Rasio Box whatever it is,
HTH,
Philip.
HTH,
Philip.
I heard that, The 23MM will cost you axles if you clip anything or jump and land badly?
It wont be a proper Truggy just look like Merlins Collari Savage, Maybe be a Bit Lower :rolleyes: .
My spellings As Bad as Phillipalli's :lol: !
I will have a Custom radio box With a decent switch Wich Will have a LED In so it Will indicate that the Batts are on or Off!
Yeah but dont Clip or land Badly,
If you want to do some Jumps keep the Stock Wheels/Tires on,
Not as hard on Landing with the 40 Series,
I not even going near a Jump with the 40 Series on my LST, For the 5 Mins just change them to stockers,
HTH,
Philip.
