Posted
ESC does efect the run time some ESC use more power than others but most of the time you will get more run time out of an ESC than a MSC also how many turns your motor is can well will efect run time the lower the less run time.
also as for batts it depends but as a general rule the higher mah the batt/batts are the longer there last.
Posted
ok thanks for the help
