Garry Posted July 13, 2005 Share Posted July 13, 2005 Who has one and whats your spec? I've got one on the way. Quote Link to comment Share on other sites More sharing options...
Nick Posted July 13, 2005 Share Posted July 13, 2005 Mine: Gorilla Straps Gorilla Chassis RPM Arms Fastrax Stiff Springs ESP Wheelie Bar Hitec 645MG Raven Aluminum Skids Fastlane Aluminium Bulkheads RPM Shock Towers MIP CVDs Run on 14 cells (GP3300 @3700+). Going to lock it into 2nd gear soon as 1st is destroyed. Yours all stock? Does it happen to have SuperMaxx arms and Integy Bulks... EDIT: Nevermind, you traded for Phils I see. Quote Link to comment Share on other sites More sharing options...
Nick Posted July 13, 2005 Share Posted July 13, 2005 Out of intrest, why did you trade your E-Rex for an E-Maxx? What do you hope to achive with the Maxx? Quote Link to comment Share on other sites More sharing options...
Garry Posted July 14, 2005 Author Share Posted July 14, 2005 I have my reasons.....Find out soon. Quote Link to comment Share on other sites More sharing options...
Nick Posted July 14, 2005 Share Posted July 14, 2005 Don't you dare get Brushless for it! Wish I had the money... Quote Link to comment Share on other sites More sharing options...
MattyMaxx Posted July 14, 2005 Share Posted July 14, 2005 lol, you made this thread just so i'd have to write it all out, well **** you garry, lol!!!!! I aint spending hours writing them all down, so i just post a pic laterz! Cheers Matt Quote Link to comment Share on other sites More sharing options...
Garry Posted July 14, 2005 Author Share Posted July 14, 2005 lol, you made this thread just so i'd have to write it all out, well **** you garry, lol!!!!! I aint spending hours writing them all down, so i just post a pic laterz! Cheers Matt ← Copy & Paste Matt... BTW, anyone got any opinions of the Gorilla carbon chassis? http://www.rchopups.co.uk/item--G2-X-Brace...ssisCarbon.html Quote Link to comment Share on other sites More sharing options...
MattyMaxx Posted July 14, 2005 Share Posted July 14, 2005 the carbon chassis, isnt worth it, it is only slightly lighter, but being an emaxx and the bodyshell is higher that it, it can receive impacks easily and break very easily! Cheers Matt Quote Link to comment Share on other sites More sharing options...
Nick Posted July 14, 2005 Share Posted July 14, 2005 Like Matt said, it isn't worth it unless your a hardcore racer. The weight difference between the ally' one is minimal and if you hit it badly it snaps. Don't get Gorilla Chassis from UK either, well expensive. Quote Link to comment Share on other sites More sharing options...
Toon Posted July 27, 2005 Share Posted July 27, 2005 I have an E-Maxx. It isn't stock. In fact, it would be far quicker for me to list the stock parts on it than all the hopups. So here goes: bumpers + mounts, bodyposts, motor plate, transmission case (well, half of it anyway). That is all... I know you've seen my E-Maxx many times before Matt, but I've got the new Gorillamaxx single-speed coversion on it now! Quote Link to comment Share on other sites More sharing options...
MattyMaxx Posted July 27, 2005 Share Posted July 27, 2005 ooo, is that gorilla cool? I have just got fully alloy tranny, on both 1st and 2nd! Still like hearing them changes, sounds so good! Cheers Toon! Matt Quote Link to comment Share on other sites More sharing options...
Toon Posted July 27, 2005 Share Posted July 27, 2005 (edited) It basically locks the transmission in 2nd gear, completely removing half of the transmission including 1st gear (along with one idler gear and half the top shaft), meaning the shifter servo and linkage can also be removed. You could just leave the E-Maxx in 2nd gear and never use 1st, but with this mod my truck lost a total of 185g (~6 oz.) in weight. Not a huge amount by any means, but every little bit helps, and the truck is now just under 12lb RTR. The brushless setup I am running pretty much made 1st gear useless anyway, but now I can just blast around without ever having to think about changing gear again. I did have a problem using it with my generation-1 set of the Ultramaxx gears though, as the GMaxx 'coupler' which locks into the 2nd gear, doesn't fit. As you can see, the coupler has straight edges at the top/bottom where it slots into the 2nd gear, which fit the stock gear perfectly. However, the Ultramaxx 2nd gear has rounded edges, meaning that the coupler will not fit into the gear without some modification. As I don't have the facilities to modify the gear/coupler so that they will fit together properly, I am now just using the stock plastic 2nd gear, with one Ultramaxx idler. And it's running great, no problems so far... Edited July 27, 2005 by Toon Quote Link to comment Share on other sites More sharing options...
MattyMaxx Posted July 27, 2005 Share Posted July 27, 2005 lol, get a dremel toon and get that baby sorted! i used to run a modified tranny which was locked via a couple of self tappers! lol. but candyman gave me the tranny at a good price so, i wnwent for that, its has supermaxx idlers and ultramaxxed dmain drives. there all sweet but on 16cells weight aint a problem! lol Cheers Matt Quote Link to comment Share on other sites More sharing options...
