Twin detanator question
monty77
Quick one here. I have an LRP ESC that I'd like to use with the twin det, but the car has 2 motors. Is it ok for me to simply make a Y split lead to power both motors from the ESC? The LRP is the 11Turn limit one and I'm using std motors.
Thanks!
Adam
As long as you are using the standard sealed 540 motors you SHOULD be ok with a low limit speedo like your LRP, as long as you are only using 1 battery pack.
Yes, making a Y-adapter won't be that difficult for you to make, one way that'll be the easiest is to use the msc wires, just cut them off and fit a bullet connector. With the LRP's 11 turn limit you'll be ok down to 17 turn w'out any overheating prob's.
Cool...thanks people. Y lead made and working great :)
Cheers,
Adam
