stripped spur advise
davewilkinson
With the 52th spur gear you will get a very slight improvement in acceleration and loose a small amount of top speed.
If you get a smaller clutch bell you will notice a difference with it accelerating quicker.....larger one means more top speed.
I was running a 14th clutch bell with a 52th spur, it was good for off road.
Hope this helps.
Tony
when insalling the new spur gear its really important that you check all the screws around the engine plate,engine and tvps are present and tight as this can be a cause for the spur spripping.
will do.......... thing is i think it may have something to do with me appling WOT whilst against a step.
i was right over the otherside of the beach and couldnt be bothered to walk over (reverse mod needed!)
anyhow i thought i could climb the step, but it was obviously too high and stripped the spur as it couldnt move forward...
anyway, got another 30 mins bashing out of it by moving the engine close to form a tighter mesh,..... lol its totaly gone now :P
Your slipper sould have stopped it from stripping though.
???? dont know then....
i havent touched messed with it since it came out the box..... all completly stock....never had any wear on the spur gear...ie all teeth fine...after around a gallon of fuel.....
it was def this step incident which caused it...........
am i thinking slipper to tight then?
The slipper clutch shouldn't slip that easily IMO, what i think might of happened is the clutch bell may of got hot as the shoes would of beeen trying to "bite" the clutch bell and heat has been transfered to the spur gear making it soft.
with the stock 25 do the nut on the front of the spur gear right up tight then back it off 1/4 of a turn and that should be fine, if you notice it slipping at all then just nip it up a bit more. :)
exactly what I do with mine
sound like the most likely thing........
anyhow doesnt matter now as i need a new one.......
thanks for the advise regarding tightning it up
My Savage 4.6 went through 3 spur gears in the first couple of days, but now I found an ALMOST FOOLPROOF way of getting the mesh right.........
1. when change the spur (I remove the engine, How about you guys??)
tighten the engine block back to the frame just enough not to move, with the gear TIGHT against the spur then roll the savvy back and forth a few times (this pushs the engine gear square with the spur(making sure the engine stays square to the frame as well then just nip up the 4 engine bolts and presto!!! ..........had the same plastic (49t) spur for nearly a month.. :)
2. just run a strip of paper through the meshing, should get a nice concertina effect, but should not have any cuts or tears (if so loosen bolts and roll again)
sounds more complicated then it actually is..
yes if done correctly it's works great. :D
I hate those heavy metal spurs and clutch bells people turn to when they keep stripping spurs as theres really no need for them(there expensive too).
I have heard that people have had a few probs with the new ss with spur gears due to it being a bit over geared for the 28 engine,thus making the clutch work to hard making it hot. maybe a 47/16 would be more suited(only what i've heard i haven't owned a 4.6 engine before).
