Savage 4.6
Dark_phoenix
i just got my savage 4.6 up and runnin,
Does any1 know how to get the fuel in the engine without having a pump on the fuel tank like the savage rtr cars have ?
how to change the air filter oil coz the DVD only shows you how to change the air filter on the savage 25.
Also if you have any other tips that can help me out i would appreciate it.
:helpsmilie:
RTFM!!
its all in the manual, prime the engine by putting your finger over the exhaust and pulling the pull starter a few times until the fuel reaches the engine and is free of air bubbles. Dont do this with a glow starter attached.
The air filter just pulls off, its only held in place by a zip tie. The inner foam is what needs to be oiled, remove the outer foam by undoing the screw and removing the end cap, you can then remove the foams. Clean them with nitro fuel, re-oil the inner foam (the white one) and put them back together.
Edited by 7zark7
yeh all air filters are the same - just sponge, clean it in a bit of fuel and put some after run oil on it,
lol phoenix, you built it but can't prime it, i can prime no probs its the building part that gets me in the nutz
have fun! ;)
what does RTFM!! stand for 7zark7
Edited by dazzi220
I have found now when I try that with my 4.6 the one way just slips, so I prime it by blowing into the pressure pipe, then just pull twice and I'm off.
Grief, it all seems a tad complicated. You should get a tank with a primer-then you can just prime it once-stick your thumb on the exhaust then spin or pull the starter!!
I knew my LST was the right choice.
Got the roto backplate on now, yea thing is it was okay doing that at the start but my savvy has almost 2 galls through it now and the one-way bearing isn't liking it much, might be time for a new one soon.
Air leak city. Primerless tank is the only way to go for reliability. Blocking the exhaust is by far the best way to prime an engine, you will NEVER flood it this way.
Primers have a habit of pushing a bit too much fuel it at the end (when trying to clear air from the fuel lines), blocking the exhuast creates a backpressure to stop fuel entering the engine, preventing floods.
Edited by 7zark7
ive just finished the breakin-in, and im trying to get the Savage to idle, im findin it hard to stop the wheels from movin, ANY TIPS ?
Am i the only 1 that has a problem with the glow plug starter runnin out of power. :angry:, also how long do you need to leave the glow plug starter in the car, coz after i have start the engine, i take the starter out the sec the engine starts then the car shouts down !!!!!!!!!!!!!!!!!!!!!!!!
:angry:
the carb needs setting, turn the idle screw anti clockwise to close the carb a bit, keep tuning it until the wheels stop spinning (1-2mm gap) if its still spinning the linkages need adjusting
Edited by dazzi220
as he said above to keep the engine idling, but you kgiht struggle to keep it idling with the low speed being so rich. The reason your car cuts out when you remove the starter is because the engine is too cold. This is because the engine is very rich. Once you have given it some revs, warmed it up you can remove the starter and you'll be fine. Oh, and my starter doesn't run out of power on a field day :) 4000mAh, 20 quid from RCMart.
I am talking about a little drop of fuel.  It will not flood the engine and it kicks the engine into life for me.
But also means you'll give your engine an inconsistent initial mix, too rich then too lean. If your engine is properly tuned, and properly primed it will start straight away.
Taking off your air filter in the field is not a great idea either.
