adzee Posted June 15, 2005 Share Posted June 15, 2005 Just wondered if anyone knew im going through glow plugs so quickly? I have a Savage 25 with the original HPI Engine. Im using HPI glow plugs (although i am using the ones for a 21 engine) but my model shop says they should work fine in a 25 engine. As an example I broke 2 in a matter of 2 hours! When you look at the damage it always breaks at the point where it joins onto the bottom. ie, in between the coil & the bit its joined too. Any Ideas ? Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted June 15, 2005 Share Posted June 15, 2005 If it is still shiney and wet you have broken it because of running to rich. if it looks kind of burnt you are runnung to lean. Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted June 15, 2005 Share Posted June 15, 2005 are you using a normal glow starter? leaving it on too long? Quote Link to comment Share on other sites More sharing options...
adzee Posted June 16, 2005 Author Share Posted June 16, 2005 are you using a normal glow starter? leaving it on too long? ← Yes im using a normal glo starter & i use the rotostart to start it. The Plug does seem to look dry with slight blackness to it, you think it might be too lean? The performance of the car is great on the settings at the moment. Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted June 16, 2005 Share Posted June 16, 2005 yeh it sounds too lean, cars performances are always 'great' wen too lean, richen the hsn abit. Quote Link to comment Share on other sites More sharing options...
adzee Posted June 16, 2005 Author Share Posted June 16, 2005 yeh it sounds too lean, cars performances are always 'great' wen too lean, richen the hsn abit. ← Thanks for that, I'll give it a go. Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted June 16, 2005 Share Posted June 16, 2005 i rarely have to buy plugs must be cos I run em a bit richer than needs be? Quote Link to comment Share on other sites More sharing options...
123456 Posted June 16, 2005 Share Posted June 16, 2005 Two and a half gallons through the LST and it is still on the original glow plug. Quote Link to comment Share on other sites More sharing options...
Duff Posted June 16, 2005 Share Posted June 16, 2005 i went throgh 2 on the break in part with my xc but been runing the same one for months now and it hasnt gone yet. Quote Link to comment Share on other sites More sharing options...
