NEON & HEADLIGHT kit
Tamiyacowboy
above is the rcneon headlight kit my set is the same as above but WITHOUT the fog lamps. this is for electic or nitro (nitro needs a micro switch to work brake light) the brake light is icorporated into the rear leds but will need a esc that has this option. who needs brakes lights anyways.
next is a set of rcneon led neons in blue the bars are 2x3 inch long and 2x6 inch long. you can have just one or all four working at once these are a very brite neon and are protected well. it uses a control board in a case but this can be removed and covered n heatshrink to cut down on space
the two above items run on a pp3 9V battery but there working limits are from 7.2-9v so you could modify the plugs to run from the rx saving weight in the form of a 9v cell
offers or WHY
TC
would also swap for a set of four losi alloy adjustable rear shocks i only need four rear shock not fronts am willing to do straight swap with either the headlights or neons.
TC
would just like to say the mr4 tc custom i had for sale is now sold
