Posted (edited)
as u all know i put a post up bout my gearbox in my scoob being knarkerd well i found out wot the problem waz al the teeth on the gears had grounded down nd now ive fixed it nd it took me 4 hours
NOW it runs like a dream
heres a pic of it
scoobs
P.S. soon i will av a pic of the lamborghini shell nd i decided to paint it green
(cam not working thts y its late)
Edited by scoobs
Posted
no i already took the gearbox apart b4 rebuildin it
Posted
WTF 4 hours! sorry but you must be a bit dense to take 4 hours to do somthing like that.
and learn to spell pleeeeeease!!!!!!!!!!!!!!
Posted
yeh the car is very easy to work on so 4 hour, how the hell did it take you that long, i took me about 2 mins to split the chassis on my tl01.
Posted (edited)
i had people bothering me. my m8 (not fatboy) trying to help me but he knows nothing also my dad had cleaned some of the bearings and chassis and he left some of peices all around his garage
p.s had fatboy ringing me up to help him
Edited by scoobs
Posted (edited)
ye but im not that good at
things
Edited by scoobs
Posted
i had to take apart all of it every peice nd put it bak together
Posted
it took me bout 10 mins to replace a rear wishbone on my mr-4tc when half the screws with rounded allon heads on the screws and a few cross-threaded ones from the previous owner
Posted
Whats the best way to get stuff like that off?
Posted
4 hours? on saturday night, half ****** i fitted my tc4 with a graphite kit (replacing every plastic part with graphite apart from chubs and gearcases) in less then an hour.
i can rebuild the whole car in about 2-2hrs30
Posted
it took my m8 (not FATBOY)
3 days to build his TL-01 Subaru Impreza
Posted (edited)
with cross threaded screws u just hav to keep working with them and with flattened allon heads the best thing to do is cut the end off the allon key to get a good shape which sometimes helps but if there not going to come out you have to drill them out.
and that reminds me how do u get a piece of plastic out of the clips that you push onto the ball with the hole in the middle, my anti-roll bars hav got one in & i want to fit them
Edited by kieran
Posted
With some Tamiyas they come with hundreds of bits and when your building them as a kit out of the box new, it takes a long itme. Took me a good 5 hours to complete my Tamiya King Blackfoot - it had so many pieces! Was a joke.
Posted
All kits take time to build, my Xray took about 5 or so hours, but I was making sure it all fitted perfectly. But when I built a TT01, it only took 2 hours, everything just slotted together. :D
Posted
when i build a car for the first time..i take my time with so so i know where everything goes, so it gets built right and make sure nothing binds but after the first time....i just about know the car inside out.
like if you gave me a tc4 now without a manual, i could build it in a couple of hours.
