Hpi_matrix_stock Posted June 4, 2005 Share Posted June 4, 2005 Wheres the cheapest place to get some of these from? Or has anyone got some they can give to me (all donations will be put onto a mini t ) Quote Link to comment Share on other sites More sharing options...
Fusion Racing Posted June 4, 2005 Share Posted June 4, 2005 Wheres the cheapest place to get some of these from? Or has anyone got some they can give to me (all donations will be put onto a mini t ) ← ebay or somewhere like that. deans are quite expensive compared to other connectors. dont u already use corally connectors?? if u do carry on using them they are great. Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 4, 2005 Author Share Posted June 4, 2005 ebay or somewhere like that. deans are quite expensive compared to other connectors. dont u already use corally connectors?? if u do carry on using them they are great. ← Yeh I do normally use corrallys (better for saddle packs) but mini t batters are more stick like so the wires come out together and with corallys on they could easily short out . Iv tried ebay theres oone action for a 1 pair and it finishes in 8 days Quote Link to comment Share on other sites More sharing options...
Fusion Racing Posted June 4, 2005 Share Posted June 4, 2005 Yeh I do normally use corrallys (better for saddle packs) but mini t batters are more stick like so the wires come out together and with corallys on they could easily short out . Iv tried ebay theres oone action for a 1 pair and it finishes in 8 days ← see what i mean. they wont short if you put heatshrink around the outside Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 4, 2005 Author Share Posted June 4, 2005 see what i mean. ← See what? Quote Link to comment Share on other sites More sharing options...
Fusion Racing Posted June 4, 2005 Share Posted June 4, 2005 See what? ← hard to find/expensive Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 4, 2005 Author Share Posted June 4, 2005 hard to find/expensive ← Hmmm I may have to resort to tamyia ones Quote Link to comment Share on other sites More sharing options...
Fusion Racing Posted June 4, 2005 Share Posted June 4, 2005 Hmmm I may have to resort to tamyia ones ← NOOOOOOO not melto tamiya crapola connectors Quote Link to comment Share on other sites More sharing options...
Samari Posted June 4, 2005 Share Posted June 4, 2005 Just go to your LHS they're sure to have some. Quote Link to comment Share on other sites More sharing options...
c0sie Posted June 5, 2005 Share Posted June 5, 2005 get some from microtech, order £10 worth and theyll send em free microtech a re good for prices Quote Link to comment Share on other sites More sharing options...
vectra Posted June 5, 2005 Share Posted June 5, 2005 get them from the U.S.A they are cheap enough Quote Link to comment Share on other sites More sharing options...
c0sie Posted June 5, 2005 Share Posted June 5, 2005 vectra.. a good idea actually *cough* www.unitedrc.com *cough* Quote Link to comment Share on other sites More sharing options...
hyper-harry Posted June 5, 2005 Share Posted June 5, 2005 wise choice deans are polarity protected and also in many tests they give the best flow electricity through them compared to corallys, tamiyas & banana plugs. Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 5, 2005 Author Share Posted June 5, 2005 wise choice deans are polarity protected and also in many tests they give the best flow electricity through them compared to corallys, tamiyas & banana plugs. ← Funny, I would have though corallys are better Quote Link to comment Share on other sites More sharing options...
Samari Posted June 5, 2005 Share Posted June 5, 2005 They're basically the same but Deans are slightly better. I'm pretty sure you wouldn't be able to notice the difference. Quote Link to comment Share on other sites More sharing options...
kevinb456 Posted June 5, 2005 Share Posted June 5, 2005 i have about 20 female connectors - i could sell them to you cheap. however i dont have many males, but i do have a few. how many of each would you need? btw, deans are the shiznitz, definatly dont get tamiya, and personally i would get them over corallys. Quote Link to comment Share on other sites More sharing options...
hyper-harry Posted June 5, 2005 Share Posted June 5, 2005 it is true though but some top racers still use corallys!! Look at this!! bottom of the page shows Resistance of different connectors. Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 5, 2005 Author Share Posted June 5, 2005 (edited) Just found some that I chopped off some old battery packs a while back . I use corallys because my pro 2 is set up in a saddle pack formation so corallys are alot easy to use as they dont need wires on the batteries. The only reason I want deans is for my mini t. Also with deans you need wire so wouldnt you need to take that in to consideration? My corallys are direct on to the batts. But then theres wires on the esc and its getting all confusing!!!!!!!!!!!!! . I doubt id notice the difference either way Edited June 5, 2005 by Hpi_matrix_stock Quote Link to comment Share on other sites More sharing options...
hyper-harry Posted June 5, 2005 Share Posted June 5, 2005 Just found some that I chopped off some old battery packs a while back . I use corallys because my pro 2 is set up in a saddle pack formation so corallys are alot easy to use as they dont need wires on the batteries. The only reason I want deans is for my mini t. Also with deans you need wire so wouldnt you need to take that in to consideration? My corallys are direct on to the batts. ← I've had to do that with my sprint too. But you can fit deans or tamiyas just one of the wires has to be longer than th other so when you slide your saddle pack in the connector stays on one side and so the longer wire slides under your top deck. Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 5, 2005 Author Share Posted June 5, 2005 I've had to do that with my sprint too. But you can fit deans or tamiyas just one of the wires has to be longer than th other so when you slide your saddle pack in the connector stays on one side and so the longer wire slides under your top deck. ← hmmm well iv sacrificed a little less resistance for a neater job and a bit of cash in the pocket.A whole pack of corraly tubes cost something like a fiver which makes it a much cheaper option. Im not a proper racer (hence the pro 2 ) so it probably wont make a difference to me. Quote Link to comment Share on other sites More sharing options...
hyper-harry Posted June 5, 2005 Share Posted June 5, 2005 hmmm well iv sacrificed a little less resistance for a neater job and a bit of cash in the pocket.A whole pack of corraly tubes cost something like a fiver which makes it a much cheaper option. Im not a proper racer (hence the pro 2 ) so it probably wont make a difference to me. ← True but the pro 2 can be a competative car with the right setup and so on. Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 5, 2005 Author Share Posted June 5, 2005 True but the pro 2 can be a competative car with the right setup and so on. ← Mine goes alright, it can hold its own against most cars. The diffs need a good rebuild at the mo though Quote Link to comment Share on other sites More sharing options...
hyper-harry Posted June 5, 2005 Share Posted June 5, 2005 Mine goes alright, it can hold its own against most cars. The diffs need a good rebuild at the mo though ← Have you got ball diffs or geared? Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted June 5, 2005 Author Share Posted June 5, 2005 Have you got ball diffs or geared? ← Ball diffs I think, what are geared? Quote Link to comment Share on other sites More sharing options...
hyper-harry Posted June 5, 2005 Share Posted June 5, 2005 Ball diffs I think, what are geared? ← Geared diffs have cogs inside them!! But ball are much more adjustable!! Quote Link to comment Share on other sites More sharing options...
