dgreat001 Posted May 11, 2005 Share Posted May 11, 2005 I went on my savvy yesterday and it was running perfect, then I took it out today and I tried to start it and the pull start tries to start it a little bit but then it just pulls without trying to start. I had this problem before when I changed the slipper clutch but I just moved the engine around and it was fine but I’m having to luck with this one .I’ve tightened the slipper all the way so that’s not the problem I’ve put the engine in every single place it can go so its not the positioning, so I’m pretty sure its something to do with the pull start so I took it of and its fine so what’s the problem? Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted May 11, 2005 Share Posted May 11, 2005 Do you mean its slipping? if so its the one way beating, de grease it then re grease it. Quote Link to comment Share on other sites More sharing options...
momin Posted May 11, 2005 Share Posted May 11, 2005 Am not sure this will work but blow the presure pipe until you see fuel go in the carb (do this for 5 secs) Then try pull.. it will feel as tho it is flooded but just tgen loosen the glow plug a little. it will fel hard at first then go back to normal.... Quote Link to comment Share on other sites More sharing options...
Merlin Posted May 11, 2005 Share Posted May 11, 2005 Sounds like the one way is slipping a bit to me too....... Quote Link to comment Share on other sites More sharing options...
dgreat001 Posted May 11, 2005 Author Share Posted May 11, 2005 is that the thing that the pull start is attached to. Quote Link to comment Share on other sites More sharing options...
momin Posted May 11, 2005 Share Posted May 11, 2005 Yes. The long thing wich. clips in the pullstarer. Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted May 11, 2005 Share Posted May 11, 2005 Ok take the pullstarter of the back plate, then on the chaft sticking out of the engine there sould be a big bearing, this is the one way bearing, soak it in brake cleaner overnight then flush out with WD and re grease. Quote Link to comment Share on other sites More sharing options...
dgreat001 Posted May 12, 2005 Author Share Posted May 12, 2005 (edited) right i took the backplate off and the black nut was there but i dont know how to take it of.What do you mean by brake cleaner?? Edited May 12, 2005 by dgreat001 Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted May 13, 2005 Share Posted May 13, 2005 Ok you souldnt have taken the actual backplate off just the pullstarter, by brake cleaner i mean the stuff thats in an erosol can that you flush traffic dust of brakes with. Quote Link to comment Share on other sites More sharing options...
