Bearings
kieran
just get a set of rubber shielded bearings..take one seal off and flush them out, re lube them and put them in your car (with the open side facing inwards so no dirt can get in)
or those metal sealed bearings from jangdstore, i use em in my TC3 and TC4 and they are top class. If you want them to super free, place them in the lid of a tin of brake and clutch spray cleaner, and spray them with the barke and clutch cleaner and they will spin about 5-10 seconds longer than without sparying them.
a good drivetrain will spin for about 7 seconds....a drivetrain that spins for about 10+ has a fairly heavy rotating mass.
yes, a free drivetrain will spin easily but one that spins for a long time isn't good.
metal shielded aren't the best, they are dust proof but not water proof....they will rust easier if you use your car when its wet.....
also gr1bbo wouldnt that just degrease them so that they run dry, i wouldnt think thats to good for the bearings.
i always run my bearings dry...just clean them out after each meeting
if your just bashing it isn't even worth taking a shield off and flushing them out.
lol, everyone thinks this...but they suck, only good thing about them is they are resistant to temperature more than steel ones (but our bearings don't get hot enough for that to effect anything anyway)
they are brittle, rough and are overpriced for what they are.
o rite i think i read it in rrci and they said it freed up the drivetrain a bit. im not all that competative so i just use the ones that came with my mission
i have ceramic eering in my skateboard and will say they knock the socks of the abec 7's i had
not sure in rc as the wieghts carryed differ alot but while skating i found ceramics better as overheating didnt happen as much on the vert ramps
any bearings will do just for bashing make sure you clean that real thick c**p grease out and relube with a good quality lube and thin coating, works for me al the time :lol:
TC
i'm suprised you aint shattered teh ceramics when you land....they are very brittle.
the best bearings to get for smoothness are roller bearings, steel rollers to....because they are so free and smooth there is less friction so don't heat up very much at all.
however if you get a heavy side impact they will often collapse..also fairly expensive (about 3.50 a bearing compared to about 2.80 for a normal ball one)
