tc3 pics wanted please
c0sie
if anyone here owns/races a tc3, can they either post me some pics up on here, or email them to me at the addy in my sig please?..
and a spec list would be good too..all helps with this learning lark lol
http://www.msuk-forum.co.uk/uploads/111152...ry_436_2_237661
An old pic but shows the chassis.
Current spec of mine is:
.Bluebird high speed servo (shown)
.Trinity monster quad mag stock
.Standard reciever
.Fantom matched GP33's
.Take Off CS22's
Hop-ups are:
.IRS blue alu servo and transponder mount
.IRS blue alu spur mount/adapter (not fitted in pic)
.IRS blue alu centre shaft bearing cover thing (again not shown in pic)
.Carbon propshaft
Edited by Mike D
nick,
when you made/bought your cell pack..why did you opt for the 1 cell ontop of the others as you have done, rather than having 7 cells in a single layer with the foam padding removed?...
any reason behind the logic?
Heres my '3' with these specs:
Nosram dominator power speedo
Sanwa RX-311 reciever
Hitec HS645MG Servo
Sanyo 3600 batteries
Reedy Quad 19 spec motor
Sanwa Gemini II radio
Graphite all around
Team orion fresh kicks shore 37 and 40 foams
RPM Bumber
Trinity foam bumper
Yeah Racing metal sealed bearings
in one picture i've compared with my nearly built TC4, which everyone looked at and said "it's the same car as the TC3, but i totally diasgree, infact the majority of parts are new. When i race this car, i find it really easy to set-up and to drive, its fairly balanced and gives you 'feedback' when you make set-up changes etc.
ben, will you be racing tc4 this saturday? if so i got a fairly good foam setup for you to try if you want....i can lend you the springs if you don't have any....you might want to get some 4 deg castor blocks to though.
A TC3 you want to see is boyracer_007's - He has sold it now, but I tell you it was awsome.
I don't race mine, or bash as such. I just use it on the local tennis courts and my street.
wondered why it looked so clean and new :P
yes i will. I am going to try the FT settings though, just to get used to the car.
the kit setup is ok but you scrub off a fair bit of corner speed (especially with the plastic chassis)....after you tried the kit setup throug silver springs on the rear (if running rubber) if not then put red front and gold rear....would be much better.
