doom56 Posted March 22, 2005 Share Posted March 22, 2005 i have just noticed my 2nd gear spur is lose on one side is it a pin whats gone missing or snaped? it does not slip or anything just wiglles Quote Link to comment Share on other sites More sharing options...
Colt Posted March 22, 2005 Share Posted March 22, 2005 I think it might be one of the screws at the base of the car, but its me ur hearing from lol Quote Link to comment Share on other sites More sharing options...
doom56 Posted March 22, 2005 Author Share Posted March 22, 2005 Na wont be the engine mound as its the gears on the shafts not on the engine The bells are ok just that one gear moves Quote Link to comment Share on other sites More sharing options...
mth Posted March 22, 2005 Share Posted March 22, 2005 does it still change gear? on my G4 and ntc3 both spur gears were fairly loose while the car wasn't moving...but then again i had centax clutches on both...dunno if that makes a difference. Quote Link to comment Share on other sites More sharing options...
doom56 Posted March 22, 2005 Author Share Posted March 22, 2005 I still changes gear no problem Quote Link to comment Share on other sites More sharing options...
kevinb456 Posted March 22, 2005 Share Posted March 22, 2005 well the only 2-speed car ive ever owned is my LST. the other 2 nitros ive had were both single speed, and my other car was an electric. so from experience with an LST which is probably very different - losi designed it so that it wobbled, but it didnt really matter because when it got moving it self-centered anyway because of the rotation. has it always wobbled? is it just the 2nd spur and not the first? have you taken it apart to find out why its wobbling? Quote Link to comment Share on other sites More sharing options...
doom56 Posted March 22, 2005 Author Share Posted March 22, 2005 no it started wobbling just before xmas now and nope does not get any loser then that as it is so i guesing a pit is ether snaped or missing Quote Link to comment Share on other sites More sharing options...
Delboy Posted March 22, 2005 Share Posted March 22, 2005 If you move the engine clutch bell away from the 2 speed gears, does the second gear spin freely on the shaft? the idea is that it shouldn't be connected to the shaft until the rpm is high enough for the centrifugal clutch to engage that gear. The 2nd gear on my CEN wobbles alot when not engaged. The inside of the gear may have become worn allowing an increase in play? presuming the gears are plastic. Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted March 23, 2005 Share Posted March 23, 2005 the gears on my 4 tech move side to side along the shaft a bit but not really wobbeling. Quote Link to comment Share on other sites More sharing options...
mth Posted March 23, 2005 Share Posted March 23, 2005 only thing i can suggest doom is to get an exploded diagram off traxxas website, take your clutch apart and look for any parts that are broken/missing and replace them if there are any missing. or if there are any parts severely worn then replace them. Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted March 23, 2005 Share Posted March 23, 2005 huh why would he want a traxxas one if its a thunder tiger? Quote Link to comment Share on other sites More sharing options...
mth Posted March 23, 2005 Share Posted March 23, 2005 thats what i just thought...what is wrong with me today well, go to the thunder tigre website and get an exploded diagram (unless there is one in your manual) Quote Link to comment Share on other sites More sharing options...
doom56 Posted March 24, 2005 Author Share Posted March 24, 2005 thats what i just thought...what is wrong with me today well to add tro that its not the cluch side its the other side if you know what i mean Quote Link to comment Share on other sites More sharing options...
mth Posted March 24, 2005 Share Posted March 24, 2005 the clutch isn't just the clutch bell on the engine, the clutch is also like the sour gears and the clutch system in there. Quote Link to comment Share on other sites More sharing options...
rcmaster Posted March 24, 2005 Share Posted March 24, 2005 is it effecting ur cars performance in any way? or will it eventually come propper loose and cumin off? Quote Link to comment Share on other sites More sharing options...
doom56 Posted March 25, 2005 Author Share Posted March 25, 2005 no no not efecting the proformance in anyway just a wonder thats all Quote Link to comment Share on other sites More sharing options...
