Soldering station
Hi all, after finally realising my 35 yr old Weller soldering gun is past it's best, decided to get a decent soldering station. What would you recommend, hopefully budget friendly,lol 😄
I use a snap on gas soldering iron, it also works really well with the soldering tip removed to heat stubborn bolts https://www.ebay.co.uk/itm/146455463742?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=x9lgoqkltxq&sssrc=4429486&ssuid=MRHag3XmRgm&var=&widget_ver=artemis&media=COPY
Edited by wolfie1
If you're still looking, grab yourself a KSGER T12, its waaaaaaaay overkill for RC and absurdly cheap too, I've had mine around 6 years now an the prices have dropped from the £130 I paid to under £60 or even less if you don't mind buying from the usual Chinese marketplaces.
I haven't found anything in RC it won't solder yet. Just double check listings as some are mains powred, others are 12v.
