SOLD!
ostewart
Up for sale is my trusty SCX-10 II, it started life 6 years ago as a bog standard raw builders kit. Since then it's been an incredibly reliable and great truck, run at SST and EAST events as well as just local trailing.
It has the following:
Injora chassis rails
Metal shock mounts on the chassis, with metal panhard mount
Metal chassis braces
Injora overdrive front diff gears
Injora standard rear diff gears
Stock transmission
Stock single piece axles
SSD titanium links all round (313mm wheelbase)
Brass diff covers
Gmade 1.9 beadlocks
Proline Toyo open country tyres with dual stage foams (only had one run at EAST)
Absima 85mm shocks
Electronics:
Holmes Torquemaster Expert 35t motor (brushed still have plenty of life, I have some spare too).
Hobbywing 1080 ESC (original model)
PowerHD 25kg servo (could do with new o-rings if you're fussy)
Bodyshell is a proline bronco (313mm) the paint job isn't great and is starting to crack in places sadly. Comes with lights fitted.
Comes with a rare Chevy body too.
It has brand new bearings all round (aside from the open ones in the diffs which were cleaned and re-greased).
No radio gear.
A ton of spares including a new axle housing, brand new axle shafts (boom racing Phat ones!), some brass bits, original shocks, original links (for all wheelbase options), tons of rod ends, all random plastics and the manual. Too much to list separately.
Honestly this has been a great rig, it's been well maintained and always had the bits it's needed.
Local collection or drop off within a sensible distance is preferred due to the amount of bits.
£300!
I can post if needed, I'll consider sensible offers however the price is fair for all that's included.
Edited by ostewart
  • ostewart changed the title to SOLD!
  • Gaz! locked this topic
