Stock trx4m bronco 1,18 wheels
Jimmie
Typically with Traxxas (other companies do it too!) the bead on stock tyres differs from company to company so Injora tyres wont work as the bead is much smaller, I’d personally recommend you swap out the stock wheels too, for what they cost now too, other benefit is of course more low down weight so will be much more capable on the rough stuff.
if your dead set on using the stock wheels, the Chevy and Ford High trail tyres would be my choice, the Mickey Thompson Baja pro’s they have really good grip although not that “sticky” a compound, just to complicate things a little more, im unsure whether they wouldn’t rub the arches of the body as they are bigger.
Hope that helps a bit :good:
