wolfie1 Posted January 9 Share Posted January 9 That was exactly what i was thinking about, at work we use that same lead to power generators when doing software updates on cars Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted January 10 Author Share Posted January 10 10 hours ago, Stormbringer said: If they cant find the lead you could just get the 1 you linked to above Is that gonna be safe enough though? 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted January 10 Share Posted January 10 the leads rated to 220v x 10a so thats 2200 watts your charger will be charging at a max of 400 watts the output voltage of your charger will be say max eg 20v at 20a but your charger wont be drawing more than 2a to give you 400 watts so yeh i would use that kettle lead on the charger if it was mine 1 Quote Link to comment Share on other sites More sharing options...
Partydaz Posted January 10 Share Posted January 10 You probably got one in a draw somewhere, most tv`s , kettles, pcs come with them 🙂 Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted January 10 Author Share Posted January 10 10 hours ago, Stormbringer said: the leads rated to 220v x 10a so thats 2200 watts your charger will be charging at a max of 400 watts the output voltage of your charger will be say max eg 20v at 20a but your charger wont be drawing more than 2a to give you 400 watts so yeh i would use that kettle lead on the charger if it was mine Im so glad youre clever. I just thought this charger can charge at 15.0a which is more than the 10a fuss. Hows this though? I did order that lead anyway. It was “Delivered-Handed to resident” today. I wasn’t even in the City when this happened. Amazon wont help till the 14th So Im no closer 😕 The seller has found the original so is posting it out at some point too so maybe this isnt going to be such a failure in the future. 1 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted January 10 Share Posted January 10 The generators that we use give out a constant 50a of power at 14. something volts and are totally fine Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted January 10 Share Posted January 10 maybe the amazon driver left it in an obscure place like between the wheely bins or somewhere like that Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted January 11 Author Share Posted January 11 Got the lead 🙂 all working fine. I wont even charge at 20a but it appears capable of it. Should hopefully be able to charge 2 4s Lipo’s at 10.0a 3 Quote Link to comment Share on other sites More sharing options...
