GMade GS02F Spider Kit
JonnyUK
Not much done, but it's a start.
Never had one by this brand before but it seems quite good quality and strong axle plastic.
Trying to change to stainless screws as I go along but there's a couple of sizes I don't have, I'll swap them in the future.
Also changing some bearings to rubber sealed in places which are exposed to dirt.
IMG_20241124_143748807
IMG_20241124_170302453
Just started on the gearbox this evening, I wrongly thought that the kit came with the optional 30t gears for non overdrive. It doesn't, so for now it'll have to be slightly overdriven to the front axle. Should be ok as long as not running on tarmac.
Edited by JonnyUK
2 speed gearbox done this evening.
IMG_20241126_135838290
This setup makes it impossible to visually check the pinion and spur mesh. I think the mesh is correct, it's definitely not too tight. The only way to see it would be to cut a hole in the plastic and then seal it with a grommet or something.
 Little bit of motor plate flex due to the plate only being fixed in place by one screw and nut.
If it becomes a problem I'll have to see if any metal motor fixings exist.
Really wasn't happy with not being able to visually check the gear mesh and also the movement of the motor plate was bugging me.
So cut a round hole and can just see the pinion and adjust the mesh a little.
IMG_20241128_134754774
Then filled the hole with a rubber grommet.
I'll need to find a better grommet without a hole but it'll do for now and I've blocked up the hole with some plastic rod.
IMG_20241128_145731526_HDR
IMG_20241128_145800994_HDR
Also did a lot of measuring and double checking internal clearance before drilling through the housing and into the motor plate to fit some extra screws.
IMG_20241128_144525052
IMG_20241128_144513878
There is now zero play and no movement of the motor.
11 hours ago, wombat said:
Loving this thread, I keep getting the urge to build a kit, problem is deciding which one, 🤔
I keep popping on this to see it being built to scratch that building itch 🙂, these do look a nice bit of kit 👍
Gearbox and links fitted.
IMG_20241129_135043260
IMG_20241129_135056926
Receiver box, although I may have to relocate this later.
IMG_20241129_135135022
Front and rear (forgot to take photo of rear) axles fitted and connected up.  Can't fit a servo horn yet as the aluminium ones I have might not have enough clearance.
IMG_20241129_141328935
IMG_20241129_145353828
IMG_20241129_145405592_HDR
I will be removing the gearbox again next week, decided to run it without the front overdrive so I've ordered a couple of 30t gears. Should be a simple swap because they both fit just behind the spur gear housing.
Spent a a little while today cutting down stainless screws due to not having the correct lengths. It's fine fitting them a couple of mm longer if it's a through hole but some aren't.
Won't get anything done to it Saturday as out walking with the kids... probably in the rain.  Then Sunday morning going to have a quick scoot round the local car boot in case any cheap RC's are there. Paid £35 for last one, after a clean up and check over, sold it for £160 💷😁
I was trying to decide which kit to buy, didn't want a RTR.  Saw this one in red and really liked the look of it.
An RC shop on eBay, Align Trex I think, had two for sale. Ebay was running their own discount on some shops so ended up getting it for less than £297 delivered.
I've had a few things from Align Trex and saved some pennies they do get discount codes popping up and sales. Beginning of summer it was a toss up between a G made kit or Element kit I got the element kit because it popped up cheap.
Watched some videos of the G made spider kit and it handles trailing and crawling well...I don't need another crawler but oh I'll crack as crawlers is what I like to use in winter 😀
Little update, very little 😆
Didn't order the two gear kit, instead ordered 2x 30t gears GM60070 because they looked the same (couldn't find an online photo of underside) and these were a couple of quid cheaper.  One gear is different but if leave the spacer on the shaft then it still fits the pin and lines up exact etc.
IMG_20241202_175822198_HDR
The outer gears in the left of photo.
IMG_20241202_185101754
Then screwed gearbox back together and refit it to chassis.
Also fit the front inner arches and front brace with fan mount.
IMG_20241202_192300629_HDR
IMG_20241202_192238505
Pretty sure I have a fan that'll fit plus I'll see if I can make a motor heatsink fit under the brace.  It probably won't need cooling though as there hasn't been an overheating problem on the same motor in the 6kg TRX4, double what this RC will end up weighing.
Shocks fitted.  Went with a set I've had for a while, got them from JK and same length as OEM. Very smooth cheap shocks.
Just had to play about with different spacers top and bottom.
IMG_20241203_141617651
IMG_20241203_141623060
IMG_20241203_141808674_HDR
IMG_20241203_141829958_HDR
IMG_20241203_141845162_HDR
Servo fitted for the 2 speed.
IMG_20241203_141647721
The only steering servo horn which I had with the same height and clearances was a double sided one, so I cut one side off.
The other dimensions are exactly the same as the kit plastic one so steering lock is the same.
IMG_20241203_145406916_HDR
Temporarily fitted the waterproof receiver box lid.
IMG_20241203_171736273
Put the adjustable battery carrier together. At full stretch it's slightly longer than the Traxxas 2s 7600mAh I'll be using.
IMG_20241203_185643676
IMG_20241203_191409592_HDR
Battery mount is only screwed to the chassis in two places and the middle rear rests on the gearbox. Pretty much zero movement of the mount once screwed down.
Need to glue some thin foam onto it to give the lipo a bit extra protection.
Planning to buy, or make, some lights for the light bars etc sometime in the future. They are available to buy but quite expensive. Flat LEDs so I should be able to buy some somewhere.
IMG_20241204_130511654
IMG_20241204_130520838
IMG_20241204_132025166_HDR
And rear bumper.
IMG_20241204_131915992
IMG_20241204_132003262_HDR
Side bars fitted.
IMG_20241204_130555820
The kit rims have zero offset from centre.  Here's how they sit.
IMG_20241204_135630569_HDR
Got these Meus aluminium beadlocks secondhand and they also have a brass inner section, not too heavy but heavy enough.
Been playing about with the different ways of building them and decided to have the deep rim look. They only stick out by 1.5mm extra each side so should look ok.
IMG_20241204_133921728
Going to use these inserts from SC Models.
Went for blue which is medium stiffness.
IMG_20241204_144606859
12mm hex fitment. However the centre hole is quite large, I could just use metal washers as spacers but these Tamiya bushes fit perfect. So I might use them or 4 bearings of the same size, might confuse some people because it'll look like free spinning wheels on all four corners.
IMG_20241204_140347927
IMG_20241204_140425493
The combination of different inserts, rims and tyres is making fitting the beadlocks very awkward. Inserts are holding the tyres away from dropping into place.
The ribs on the insides of the tyres weren't helping, seemed to be snagging on the edge of the inserts. Didn't want to cut them so instead I turned the tyres inside out and cut the ribs off.
IMG_20241204_175133354_HDR
Seems lots better, still very hard the get the tyres lip to drop into the beadlock. After rebuilding one a few times I think it has now worked, from what I can tell it looks like the beadlock is secure all the way round.
I think wiping a bit of oil onto the rubber would help lots, but then I don't want to make it easier for the rubber to slip out in use.  Maybe a mix of water and washing up liquid would work, it might dry sticky.
Anyway going to persist tomorrow and try to get the other three wheels finished.
Wheels finished.
IMG_20241205_141513091
IMG_20241205_141605989
Bearing fitted as a spacer, snug fit.
IMG_20241205_144345510
Wide flange on the nuts covers most of the spacer.
IMG_20241205_144408983
Next stage would be getting the bodyshell ready for painting but I might put that off until after the weekend.
So next I think I'll get on with fitting the receiver, ESC etc. May need to lengthen the motor cables depending on where things fit.
Edited by JonnyUK
Aye them wheels look well lush 😍. I always struggle getting beadlocks right takes me a few times to get it sit ok, then I am double checking it's not going slip out the rim 😅
My experience of beadlocks is that even when they are sitting correct, if you pull them too hard to check then they will pull out. Don't come out when driving so must be normal.
Today realised that I couldn't fit the ESC until I'd worked out the space with the body fit, so I had to cut that out first.
Pretty thick material but the score once and snap with pliers method worked.
Still needs the edges finishing by sanding to get them straight and smooth.
IMG_20241206_134130483
IMG_20241206_134142037
IMG_20241206_142614763_HDR
IMG_20241206_142628224
No place to fit the Traxxas ESC apart from where it is in this photo, this orientation should work best at getting the cables away from things and allow the body to sit down correctly.
Will need to extend the two motor cables by about 12 inches to be able to run them under and around things, and at least one servo extension cable for the steering. I already have a spare battery cable with the flylead for lights which makes the battery cable long enough.
IMG_20241206_180203532
1 hour ago, wolfie1 said:
Have you decided on a colour?
Think I'll end up doing it red because seeing it red is what sold it to me.
Might have a play with some stencils, not sure yet.
